specialized pitch comp
Tema en 'General' iniciado por chemac4, 20 Abr 2009.
  1. chemac4
    chemac4 Novato
    31 Mar 2009
    HOLA A TODOS.
    ME LLAMO JOSE Y TENGO UNA DUDA QUE ESPERO ME PODAIS SOLUCIONAR.
    VEREIS EL OTRO DIA ME COMPRE UNA SPECIALIZED PITCH COMP DEL 2008 EN OFERTA POR 999E.
    CON ESTAS CARACTERISTICAS:
    CUADRO
    Cuadro con tubería M4, tubo diagonal doble ORE, desviador DMD, pivotes de giro con rodamientos sellados, puntera reemplazable, guiado de cables por tornillos, 150mm de recorrido
    AMORTIGUADOR
    X Fusion 02R, Custom para Specialized, ajuste de rebote., 7.875x2.25
    HORQUILLA
    Rockshox Pike 327 para Specialized, 140mm de recorrido, muelle U-Turn, tubo de dirección de alumino, ajuste de rebote., Maxle 360 includedo
    DIRECCION
    1-1/8 Threadless, loose ball bearings w/ seals, black steel cups
    POTENCIA
    Specialized, 8 deg. rise, four bolt 31.8mm clamp, 3D forged. S:60mm, M/L:75, XL:90mm
    MANILLAR
    Specialized mid rise 31.8mm, 6061 alloy, 660mm wide, 8 degree up, 8 degree back sweep
    PUÑOS
    Specialized thin lock on grip, alloy bar ends
    FRENO DELANTERO
    Hayes Stroker Ryde hydraulic de disco 203 mm rotor
    FRENO TRASERO
    Hayes Stroker Ryde hydraulic de disco 185 mm rotor
    MANETAS DE FRENO Hayes
    DESVIADOR
    Shimano SLX FD-M660, E-Type
    CAMBIO
    SRAM X-7, 9-speed, mid cage
    MANDOS DE CAMBIO
    SRAM X-5, trigger, 9-speed
    CASETE
    Shimano HG-50, 9-speed, 11-34t
    CADENA
    KMC X9, 9-speed w/ reusable Missing Link
    PEDALIER
    Shimano FC-M442-8, Octalink Spline, replaceable rings w/ alloy outer, S: 170mm, others: 175mm
    PLATOS
    22S x 32A x 44A, 4-bolt, 104/64mm
    CAJA PEDALIER
    Shimano BB-ES25, Octalink spline, cartridge bearking, 68mm x 118mm
    PEDALES
    Specialized, 1pc., alloy body and cage, 9/16
    LLANTAS
    DT Swiss 445D, disc, 24mm, double wall, pin joint, eyelets, 32h
    BUJE DELANTERO
    Specialized Stout disc, sealed cartridge bearing, 20mm thru axle, high/low flange, 32h
    BUJE TRASERO
    Specialized disc, sealed cartridge bearing, high/low flange w/ OS contact side, 32h
    RADIOS
    1.8mm (15g) stainless, black, alloy nipples
    NEUMATICO DELANTERO
    Specialized Eskar Sport, 26x2.3, 60 TPI, wire bead
    NEUMATICO TRASERO
    INNER TUBES
    Specialized 26x2.0, schrader
    SILLIN
    Specialized Enduro, 7mm steel rails
    TIJA DE SILLIN
    Specialized 6061 alloy, black, 30.9x350, setback head, 2-bolt micro adjust
    ABRAZADERA SILLIN
    Alloy collar w/ QR, 34.9mm clamp ID
    COMO LO VEIS?
    LA HORQUILLA ES UNA Rockshox Pike 327 para Specialized SIN BLOQUEO.
    HAY ALGUNA FORMA DE MONTARLE EL BLOQUEO?
    GRACIAS
  2. chemac4
    chemac4 Novato
    31 Mar 2009
    Nadie por ahí?
  3. chemac4
    chemac4 Novato
    31 Mar 2009
    Holaaaaaaaaa
  4. Andreçao
    15 Ago 2006
    Es una ****** de bici. Corre a devolverla...
    No, en serio. Si ya te la has comprado es mejor que no preguntes. Como dijo César al cruzar el Rubicón "Alea jacta est". Tú ahora solo preocúpate de disfrutarla.
  5. chemac4
    chemac4 Novato
    31 Mar 2009
    Gracias por el consejo
  6. Biker Solitario
    Biker Solitario bicivagabundo
    18 Jun 2004
    Madriles
    Pues a tu pregunta, te diré que si se podrá instalar el bloqueo a esa horquilla, cambiando todo el cartucho. O sea, prepara 200 leuros.
    Casi conviene pillarse algun modelo superior de 2ª pata (p.ej. R.S. Pike 454) y puedes intercambiar las piezas para montarte una horquilla con mayores prestaciones que esa.
    De la bici a mi me mola bastante, de hecho la estuve mirando para comprarla. 2 cosas:
    - Un buen update a esa bici seria el amortiguador, a las FSR les conviene llevar un amortiguata con algun sistema de plataforma estable de pedaleo, como el Propedal de Fox, el SPV de Manitou y otros sistemas antibalanceo similares (las FSR y por tanto tu bicicleta son bicicletas que bambolean mucho al pedalear).
    - La has pillado a buen precio, yo probablemente me la hubiese comprado si hubiese encontrado una oferta tan buena por la Specialized Pitch Comp.
  7. .foki.
    .foki. adolescente venido a mas!
    22 Oct 2008
    madriz con Z
    como que no tiene bloqueo???tiene un semi bloqueo.vamos si es la misma que la que trae la pro asi es.
  8. chemac4
    chemac4 Novato
    31 Mar 2009
    bueno de momento ire tirando con lo que tengo y luego ya veremos porque es la primera vez que tengo una doble.
    Gracias por la respuesta.
  9. chemac4
    chemac4 Novato
    31 Mar 2009
    la comp no tiene bloqueo ni en la horquilla ni en el cuadro
  10. paquito123456
    paquito123456 Miembro
    24 Ene 2009
    q tal funciona me la he pillado y es la 1ª vez q pillo una doble
  11. paquito123456
    24 Ene 2009
    dime algo cuando puedas
