Vendo Specialized Epic Marathon Carbon Talla S - 2011
Tema en 'Venta Bicis-Cuadros' iniciado por holdfins, 16 Ago 2012.
  1. holdfins
    holdfins Miembro
    14 May 2011
    P1000081.jpg Ver el archivo adjunto 3020014 Vendo mi maquina montada de lujo, talla S equipada con:
    Cuadro: FACT 9m carbon front triangle, FACT IS construction, gussetless TT S/M, M5 aluminum chainstays & seatstays, tapered HT, carbon PF-30 BB, 135mm drop-outs, sealed cartridge bearing pivots, replaceable derailleur hanger, 100mm travel
    Horquilla: Specialized Future Shock E100, inertia valve, 1 1/2-1 1/8" carbon steer/crown, Brain Fade, external rebound adj., single sided air spring and damper, 100mm travel
    Amortiguador: Fox/Specialized remote Mini-Brain, inertia valve, w/ Brain Fade adjust, 187x47mm
    Ruedas: Mavic Crossmaxx ST
    Cubiertas: Schwalbe Rocket Ron 2.1 UST"
    Cambio: SRAM X.0, 10-speed, mid cage
    Desviador: SRAM X.0, 10-speed, S3 direct mount for DMD, bottom pull
    Sistema de Cambio: SRAM X.0, 10-speed, carbon/aluminum trigger
    Bielas: SRAM X.0 Carbon, PF-30, 10-speed XC double, removeable spider, S: 170mm, others: 175mm 39A x 26A, 4-bolt
    Cassette: Shimano M771, 10-speed, 11-36t
    Pedales: Resin Test Ride Pedals with toe clips, CEN std
    Sillín: Specialized BG Phenom Expert, Ti rails, 143mm width
    Tija de Sillín: Thomson Elite Setback w/ 12 degree clamp, 410mm
    Manillar: S-Works XC Carbon low-rise bar, uni-directional carbon, 660mm wide, 8 degree back sweep, 6 degree up, 31.8mm
    Potencia: Specialized XC, 3D forged alloy, 4-bolt, 31.8mm clamp, adjustable rise
    Dirección: 1-1/8 and 1.5" Threadless, Campy style upper with 1.5" lower, cartridge bearings
    Frenos:Custom Avid X.0 R SL, hydralic disc, tool-less reach adjust and pad contact, alloy backed semi-metallic pads, 2-piece alloy caliper, stainless hardware, S/M: 160mm rotor,
    Poco uso, impecable y se entrega con su garantia de por vida.
    Pesa 9 kilos.
    Precio: 2700 euros.
    OPCIÓN: Sin frenos, manetas, mandos de cambio, cambio trasero, cassete y pedales: 2200 euros
    Escucho ofertas
    Última edición: 16 Ago 2012
  2. AEROL
    AEROL Miembro activo
    9 May 2008
    Estoy interesado en el cuadro y la horquilla
  3. holdfins
    holdfins Miembro
    14 May 2011
    vendida
  4. holdfins
    holdfins Miembro
    14 May 2011
    Lo siento gracias por tu interes cierro el anuncio
