1. Este sitio usa cookies. Para continuar usando este sitio, se debe aceptar nuestro uso de cookies. Más información.
DUELO!!! Specialized FSR xc Comp VS. Trek Fuel EX6
Tema en 'Rally/X-Country/Maratón' iniciado por Dr_kilerin, 5 Mar 2007.
  1. Dr_kilerin
    Dr_kilerin Novato
    18 Dic 2006
    Pues eso, haver por qual me decido:
    SPECIALIZED FSR XC COMP:
    -Cuadro FSR M4 butted frame w/ ORE downtube, sealed cartridge bearing pivots, replaceable derailleur hanger, two sets of water bottle bosses, disc only, 100mm travel
    -Horquilla Rock Shox Recon 335, 100mm, fixed coil, lock out, turnkey damper, ext rebound adj, alloy steerer
    -Amortiguadores X Fusion 02RC, Specialized tuned, rebound/compression adjust w/ lock out, 7.0x1.6"
    -Llantas Mavic X117 Disc, 26", 32h, black, presta valve
    -Bujes Front: Specialized disc, loose ball bearing, high/low flange, 32h. Rear: Shimano M-475L disc, 32h, 8/9-speed, alloy QR.
    Radios 1.8mm stainless, black, brass nipples
    -Cubiertas Specialized Resolution 26x2.0", 60TPI, aramid bead, dual compound
    -Pedales Shimano 505 SPD
    -Bielas Shimano FCM-442-8, Octalink Spline, 9-speed, replaceable rings w/ alloy outer. 22s/32s/44A 4mm thick outer, 4 bolt 104/64mm
    -Cadena Shimano HG73
    -Piñones Shimano HG50, 9-speed, 11/34t
    Eje de Pedalier Shimano ES-25 Octalink Spline, 68mm shell, 118mm spindle, 50mm chainline
    -Desviador Shimano FD-M530, Deore, top swing, duall pull, 34.9mm clamp
    -Cambio Shimano M-751 Deore XT, long cage, standard spring
    -Manetas de cambio Shimano SL-511 Deore, 9-speed
    -Manillar Specialized XC low rise, butted alloy, 640mm wide, 6 degree up, 8 degree backsweep
    -Potencia Aluminum, 7 degree rise, OS 31.8, 4 bolt, black
    Dirección 1 1/8" threadless, black steel cups, loose ball bearings w/ seals
    -Frenos Avid Juicy 3, hydraulic disc, G2 Clean Sweep
    -Manetas de freno Avid Juicy 3 hydraulic
    -Sillín Specialized BG MTB
    -Tija del sillín 6061 alloy, black, 30.9 x 350/400mm
    TREK FUEL EX 6:
    Cuadro
    ZR 9000 Alloy main frame w/100mm travel
    Horquilla
    RockShox Reba SL w/positive and negative air pressure, Motion Control, rebound, compression, lockout, 100mm
    Amortiguador
    RockShox MC3.3 w/air pressure, 3-position Motion Control, rebound
    Ruedas
    Shimano Deore LX disc hubs; Bontrager Ranger rims
    Bielas
    Shimano Deore LX 44/32/22
    Manetas de Cambio
    Shimano Deore XT
    ?¿¿?¿?¿?¿?¿?¿? SEÑORES/AS SE ABREN LAS APUESTAS ¿??¿¿?¿?¿?¿?¿?¿?¿?
  2. lowrider
    lowrider Miembro Reconocido
    20 May 2006
    Burgos
    Si te sirve de algo, yo me he comprado una FSR 2007, y estoy contentisimo con ella. Me cuesta moverla algo mas que la anterior Decathlon (rigida) que tenia, una rockrider 7.1, pero es increible como baja
  3. cavallino81
    cavallino81 C.G.H Member
    5 Dic 2006
    Azuqueca de Henares
    Yo tengo una FSR XC 2007, y va de maravilla, baja de lujo, con mucha estabilidad y la geometria es muy comoda.
  4. davis
    davis Like water
    22 Jun 2006
    En el apartado Bicis&componentes hay por lo menos 2 post abertos sobre el tema.
    Yo tengo una EX6 y voto por ella.
  5. §atan
    §atan Novato
    1 Feb 2007
    Yo tengo una fsr 2007 y va cacho bien pa descenso
  6. jmizzu
    jmizzu Novato
    16 Mar 2007
    que tal va llaneando y subiendo? con el bloqueo contamina mucho?
    que tal va el x fusion?
  7. Xemabiker
    Xemabiker Siempre biker ast l muert
    26 Ago 2006
    ALKUZAR CENTRO
    ola yo tengo otra fsr 2007 y esta de **** madre no puedo opinar de la otra bici porque no la e probado pero esta es la lexe
  8. carlocito
    carlocito Baneado
    5 Jun 2006
    en la villa
    muchas dudas no tendras, te lo han dejado bastante claro
  9. danigs
    danigs Miembro Reconocido
    10 Sep 2004
    Calafell
    Para mi esto solo demuestra que ambas son buenas elecciones. Y concluyo eso porque el que tiene una spec vota por la spec y el que tiene una Trek vota por la Trek.
    Así que no es lógico concluir que gana la spec solo porque haya más foreros con spec que han votado... y más aun cuando muchos de los que votan ni siquiera han probado las dos bicis.
    También hay que tener en cuenta que hay algunos que tienen la Spec porque la Ex6 no se la servían... y terminaron comprando otra bici... pero su principal elección fue la Ex. Eso no quiere decir que se hayan equivocado. En absoluto.
    Para mi un dato a tener en cuenta sería si el poseedor de una Trek votara por la Spec o viceversa... y además argumentara los motivos.
    Así que mi voto, habiendo probado solo la Trek porque es la que tengo, es para la Trek Fuel Ex6... pero con cualquiera de las dos aciertas, por lo que te sugiero que valores otros aspectos como cercanía de la tienda que te la vende, precio, trato,...
  10. DrTroski
    DrTroski Me la pones Endura
    17 Oct 2006
    Tortosa
    cuanta razón tienes
  11. mtbmig
    mtbmig Invitado
    1 Oct 2006
    Granada
    macho,yo creo que estas mas a favor de la specialized porque las descrito todos los componentes con sus medidas y todo y la trek ahi muy resumida:(
    pues yo me decanto por la trek.:burladia:
