SELECT cache_value
FROM xf_permission_combination
WHERE permission_combination_id = ?
Params: 1
Run Time: 0.000051
Select Type | Table | Type | Possible Keys | Key | Key Len | Ref | Rows | Extra |
SIMPLE | xf_permission_combination | const | PRIMARY | PRIMARY | 4 | const | 1 | |
SELECT thread.*
user.gender, user.avatar_date, user.gravatar,
NULL AS thread_read_date,
0 AS thread_reply_banned,
0 AS thread_is_watched,
'' AS draft_message, NULL AS draft_extra
FROM xf_thread AS thread
LEFT JOIN xf_user AS user ON
(user.user_id = thread.user_id)
WHERE thread.thread_id = ?
Params: 531583
Run Time: 0.000188
SIMPLE | thread | const | PRIMARY | PRIMARY | 4 | const | 1 | |
SIMPLE | user | const | PRIMARY | PRIMARY | 4 | const | 1 | |
SELECT node.*, forum.*
permission.cache_value AS node_permission_cache,
NULL AS forum_read_date
FROM xf_forum AS forum
INNER JOIN xf_node AS node ON (node.node_id = forum.node_id)
LEFT JOIN xf_permission_cache_content AS permission
ON (permission.permission_combination_id = 1
AND permission.content_type = 'node'
AND permission.content_id = forum.node_id)
WHERE node.node_id = ?
Params: 22
Run Time: 0.000105
SIMPLE | node | const | PRIMARY | PRIMARY | 4 | const | 1 | |
SIMPLE | forum | const | PRIMARY | PRIMARY | 4 | const | 1 | |
SIMPLE | permission | const | PRIMARY | PRIMARY | 35 | const,const,const | 1 | |
SELECT post.*
user.*, IF(user.username IS NULL, post.username, user.username) AS username,
user_profile.*,
user_privacy.*,
session_activity.view_date AS last_view_date,
0 AS like_date
,(select sum(count_received) from dark_postrating_count where user_id = post.user_id and rating in (1,2,4,5,7,8,10)) as positive_rating_count
,(select sum(count_received) from dark_postrating_count where user_id = post.user_id and rating in (14,11,12,13)) as negative_rating_count
,(select sum(count_received) from dark_postrating_count where user_id = post.user_id and rating in (3,6,9)) as neutral_rating_count
pr2.rating,
pr.*, post.post_id, rating.fb_percent, rating.fb_positive, rating.fb_positivetotal, rating.fb_negative, rating.fb_neutral,
permission_combination.cache_value AS global_permission_cache
FROM xf_post AS post
(user.user_id = post.user_id)
LEFT JOIN xf_user_profile AS user_profile ON
(user_profile.user_id = post.user_id)
LEFT JOIN xf_user_privacy AS user_privacy ON
(user_privacy.user_id = post.user_id)
LEFT JOIN xf_session_activity AS session_activity ON
(post.user_id > 0 AND session_activity.user_id = post.user_id AND session_activity.unique_key = CAST(post.user_id AS BINARY))
LEFT JOIN dark_postrating pr2 ON (post.post_id = pr2.post_id and pr2.user_id = 0)
LEFT JOIN (
select
pivot_pr.post_id
, sum(case when pivot_pr.rating = 1 then 1 else 0 end) dark_postrating_1_count
, sum(case when pivot_pr.rating = 14 then 1 else 0 end) dark_postrating_14_count
, sum(case when pivot_pr.rating = 2 then 1 else 0 end) dark_postrating_2_count
, sum(case when pivot_pr.rating = 3 then 1 else 0 end) dark_postrating_3_count
, sum(case when pivot_pr.rating = 4 then 1 else 0 end) dark_postrating_4_count
, sum(case when pivot_pr.rating = 5 then 1 else 0 end) dark_postrating_5_count
, sum(case when pivot_pr.rating = 6 then 1 else 0 end) dark_postrating_6_count
, sum(case when pivot_pr.rating = 7 then 1 else 0 end) dark_postrating_7_count
, sum(case when pivot_pr.rating = 8 then 1 else 0 end) dark_postrating_8_count
, sum(case when pivot_pr.rating = 9 then 1 else 0 end) dark_postrating_9_count
, sum(case when pivot_pr.rating = 10 then 1 else 0 end) dark_postrating_10_count
, sum(case when pivot_pr.rating = 11 then 1 else 0 end) dark_postrating_11_count
, sum(case when pivot_pr.rating = 12 then 1 else 0 end) dark_postrating_12_count
, sum(case when pivot_pr.rating = 13 then 1 else 0 end) dark_postrating_13_count
from dark_postrating pivot_pr
use index (`post_id_rating`)
left join xf_post pivot_post on (pivot_pr.post_id = pivot_post.post_id)
where pivot_post.thread_id = 531583
group by pivot_pr.post_id
) pr on (pr.post_id = post.post_id)
LEFT JOIN xc_trade_user AS rating ON rating.user_id=post.user_id
LEFT JOIN xf_permission_combination AS permission_combination ON
(permission_combination.permission_combination_id = user.permission_combination_id)
WHERE post.thread_id = ?
AND (post.position >= 0 AND post.position < 20)
AND (post.message_state IN ('visible'))
ORDER BY post.position ASC, post.post_date ASC
Params: 531583
Run Time: 0.001084
PRIMARY | post | ref | thread_id_post_date,thread_id_position | thread_id_post_date | 4 | const | 7 | Using where; Using filesort |
PRIMARY | user | eq_ref | PRIMARY | PRIMARY | 4 | foromtb_www.post.user_id | 1 | |
PRIMARY | user_profile | eq_ref | PRIMARY | PRIMARY | 4 | foromtb_www.post.user_id | 1 | |
PRIMARY | user_privacy | eq_ref | PRIMARY | PRIMARY | 4 | foromtb_www.post.user_id | 1 | |
PRIMARY | session_activity | eq_ref | PRIMARY | PRIMARY | 22 | foromtb_www.post.user_id,func | 1 | Using where |
PRIMARY | pr2 | eq_ref | post_id_user_id,post_id_rating,user_id_rating | post_id_user_id | 8 | foromtb_www.post.post_id,const | 1 | |
PRIMARY | <derived5> | ref | key0 | key0 | 5 | foromtb_www.post.post_id | 2 | |
PRIMARY | rating | eq_ref | PRIMARY | PRIMARY | 4 | foromtb_www.post.user_id | 1 | |
PRIMARY | permission_combination | eq_ref | PRIMARY | PRIMARY | 4 | foromtb_www.user.permission_combination_id | 1 | Using where |
DERIVED | pivot_post | ref | PRIMARY,thread_id_post_date,thread_id_position | thread_id_post_date | 4 | const | 7 | Using index; Using temporary; Using filesort |
DERIVED | pivot_pr | ref | post_id_rating | post_id_rating | 4 | foromtb_www.pivot_post.post_id | 1 | Using index |
DEPENDENT SUBQUERY | dark_postrating_count | ref | user_id_rating | user_id_rating | 4 | foromtb_www.post.user_id | 1 | Using index condition |
INSERT DELAYED INTO xf_thread_view
(thread_id)
VALUES
Params: 531583
Run Time: 0.000056
SELECT field.*
ff.field_id, ff.node_id
FROM xf_thread_field AS field
INNER JOIN xf_forum_field AS ff ON
(ff.field_id = field.field_id)
WHERE (ff.node_id IN(22))
ORDER BY field.materialized_order
Run Time: 0.000072
SIMPLE | ff | ref | PRIMARY,field_id | PRIMARY | 4 | const | 1 | Using index; Using temporary; Using filesort |
SIMPLE | field | eq_ref | PRIMARY | PRIMARY | 194 | foromtb_www.ff.field_id | 1 | |
SELECT field.*
Run Time: 0.000061
INSERT INTO `xf_session` (`session_id`, `session_data`, `expiry_date`) VALUES (?, ?, ?)
Params: f0c5f6a6d942ee69e3e3ef43e1b5127f, , 1713559609
Run Time: 0.000101
INSERT INTO xf_session_activity
(user_id, unique_key, ip, controller_name, controller_action, view_state, params, view_date, robot_key)
VALUES
ON DUPLICATE KEY UPDATE
ip = VALUES(ip),
controller_name = VALUES(controller_name),
controller_action = VALUES(controller_action),
view_state = VALUES(view_state),
params = VALUES(params),
view_date = VALUES(view_date),
robot_key = VALUES(robot_key)
Params: 0, , , XenForo_ControllerPublic_Thread, Index, valid, thread_id=531583, 1713556009,
Run Time: 0.001492
SELECT activity.*, user.username
FROM xc_trade_activity AS activity
LEFT JOIN xf_user AS user ON user.user_id=activity.user_id
WHERE activity.user_id=?
ORDER BY activity.dateline DESC
LIMIT 0, ?
Params: 0, 10
Run Time: 0.000073
SIMPLE | activity | ref | user_id_dateline | user_id_dateline | 4 | const | 1 | Using where |
SIMPLE | user | eq_ref | PRIMARY | PRIMARY | 4 | foromtb_www.activity.user_id | 1 | |
SELECT title, template_compiled
FROM xf_template_compiled
WHERE title IN ('page_nav', 'bb_code_tag_code', 'bb_code_tag_php', 'bb_code_tag_html', 'bb_code_tag_quote', 'bb_code_tag_attach', 'bb_code_tag_spoiler', '_header_node.22', '_footer_node.22', '_header_post_node.22', '_footer_post_node.22', 'waindigo_quick_reply_prepend_customfields', 'waindigo_header_node_customfields', 'thread_view', 'nflj_showcase_tab_links', 'xcxt_navtabs', 'waindigo_you_are_using_as_user_loginasuser', 'waindigo_moderator_bar_loginasuser', 'dark_postrating', 'dark_postrating_member', 'dark_postrating_member_totals', 'message_user_info_extra', 'user_criteria_content', 'thread_list_item_icon_key', 'dark_postrating_member_notable_tabs', 'dark_postrating_account_wrapper', 'dark_postrating_navigation_visitor_tab', 'dark_postrating_visitor_panel', 'dark_postrating_member_card', 'dark_postrating_member_info', 'dark_postrating_message_user_info', 'xcfw_copyright', 'xcxt_headinclude', 'xcxt_trading_preferences_link_list', 'xcxt_visitor_panel_addon', 'PAGE_CONTAINER')
AND style_id = ?
AND language_id = ?
Params: 1, 2
Run Time: 0.000173
SIMPLE | xf_template_compiled | range | PRIMARY | PRIMARY | 60 | | 36 | Using where |
SELECT title, phrase_text
FROM xf_phrase_compiled
WHERE language_id = ?
AND title IN ('xcxt_trade')
Params: 2
Run Time: 0.000069
SIMPLE | xf_phrase_compiled | const | PRIMARY | PRIMARY | 106 | const,const | 1 | |
WHERE title IN ('waindigo_thread_view_tools_links_customfields')
AND style_id = ?
AND language_id = ?
Params: 1, 2
Run Time: 0.000052
SIMPLE | xf_template_compiled | const | PRIMARY | PRIMARY | 60 | const,const,const | 1 | |
WHERE title IN ('_header_node.22')
AND style_id = ?
AND language_id = ?
Params: 1, 2
Run Time: 0.000043
SIMPLE | | | | | | | | Impossible WHERE noticed after reading const tables |
WHERE title IN ('_footer_node.22')
AND style_id = ?
AND language_id = ?
Params: 1, 2
Run Time: 0.000039
SELECT *
FROM xf_notification
ORDER BY notification_id
Run Time: 0.000094
SIMPLE | xf_notification | index | | PRIMARY | 4 | | 1 | |
WHERE title IN ('GritterNotifications')
AND style_id = ?
AND language_id = ?
Params: 1, 2
Run Time: 0.000059
