*****OFERTA 850€ SPECIALIZED BIG HIT III MEJORADA*****
Tema en 'BTT - Con Suspensión Trasera' iniciado por FORNER, 3 Jun 2013.
  1. FORNER
    FORNER SEMPRE FIDELIS
    13 Sep 2005
    L´Alcúdia (València)
    La bici esta en perfecto estado de revista, solo utilizada 2 o 3 veces al año.
    La horquilla es una Marzochi 888 SL ATA la pata negra italiana no la que se fabrica en China.
    Cuelgo fotos en cuando pueda.
    TALLA M
    PRECIO: 950€
    PREFERIBLE ENTREGA EN MANO.
    LA BICI ESTA EN VALENCIA, SE PUEDE VER SIN COMPROMISO NINGUNO.
    FRAME BigHit FSR, A1 Premium Aluminium ORE TT/DT, full cartridge bearing pivots, ISCG mount, asymetrical rear triangle, 26" F/R wheel, 8.2" travel, adj geometry
    REAR SHOCK Fox DHX 4.0, 8.75x2.75", adjustable rebound, pro pedal, and bottom out, S:400, M:450, L:500
    FORK Marzocchi 888 SL ATA, 200mm travel, alloy steerer, external rebound adj, double clamp, 20mm thru axle
    HEADSET 1 1/8" Threadless, 7050 alloy cups with oversize lower cup and bearing
    STEM PZ RACING 40MM
    HANDLEBARS DA BOMB 770MM
    GRIPS MSC
    FRONT BRAKE Avid Juicy 5, hydraulic disc, G2 Clean Sweep 200mm rotor
    REAR BRAKE Avid Juicy 5, hydraulic disc, G2 Clean Sweep 200mm rotor
    BRAKE LEVERS Avid Juicy 5
    FRONT DERAILLEUR N/A
    REAR DERAILLEUR SRAM X-9, 9-speed, short cage
    SHIFT LEVERS SRAM X-7, Aluminium trigger 9-speed
    CASSETTE Shimano HG50, 9-speed, 11/34t
    CHAIN SRAM PC-951 w /Power Link
    CRANKSET SHIMANO HONE BlackSpire DS-1 guide
    CHAINRINGS 36t, 4 bolt, compact 104mm pattern
    BOTTOM BRACKET SHIMANO SAINT
    PEDALS SHIMANO DX
    RIMS Mavic EX325 disc, 36h
    FRONT HUB Specialized disc, 20mm thru axle, 36h
    REAR HUB Specialized bolt-on 135mm, hollow Cro-Mo axle w/ RD guard
    SPOKES 2.0mm stainless, black, brass nipples
    FRONT TYRE KENDA NEVEGAL 2.5
    REAR TYRE Specialized Chunder 26x2.3," 60TPI, aramid bead, 2 ply, soft compound
    TUBES Specialized 26x2.3", schraeder
    SADDLE Specialized Enduro, 8mm hollow Cro-Mo rails, SL foam
    SEAT POST Alloy microadjust, 30.9 x 300mm
    SEAT BINDER 7050 hard annodized alloy collar w/ QR, 34.9mm clamp ID, black
    Última edición: 11 Oct 2013
  2. ferran.es
    ferran.es Nomada
    14 Jun 2006
    SantaKo City
    Mp enviado.
  3. FORNER
    13 Sep 2005
    contestado
  4. FORNER
    13 Sep 2005
    perfecto estado.
  5. FORNER
    13 Sep 2005
    Se puede plantear el despiece
  6. FORNER
    13 Sep 2005
    Sigue en venta
  7. FORNER
    13 Sep 2005
    Se aceptan ofertas
  8. FORNER
    13 Sep 2005
    ESCUCHO OFERTAS SERIAS
  9. FORNER
    13 Sep 2005
    Vamos
  10. FORNER
    13 Sep 2005
    Rebajada a 1000€
  11. FORNER
    13 Sep 2005
    Venga que necesito la pasta. Preguntar lo que querais, incluso despiece.
  12. FORNER
    13 Sep 2005
    Sigue en venta
  13. FORNER
    13 Sep 2005
    Mas fotos por watsapp 615537719.
    Mp´S contestados
  14. FORNER
    13 Sep 2005
    Se podria cambiar por bici de carretera
  15. FORNER
    13 Sep 2005
    Mps contestados
  16. FORNER
    13 Sep 2005
    Escucho ofertas serias.
  17. FORNER
    13 Sep 2005
    Oferta final 950€
  18. carretilla
    carretilla Miembro
    9 May 2010
    "El pais de las maravillas"
    Que angulo de dirección tiene?
  19. FORNER
    13 Sep 2005
    68.2
    66.3
    Segun posicion del amortiguata.
  20. FORNER
    13 Sep 2005
    Un empujoncillo.
