Vendo Specialized Hardrock Comp Disc 2006
Discussion in 'BTT - Sin Suspensión o Rigidos' started by elgusdanes, Mar 14, 2007.
  1. elgusdanes
    elgusdanes G-Force
    VENDIDA!!!!
    Vendo Hardrock Comp Disc del 2006 (de Julio), en perfecto estado. Talla 17.
    Vendo por cambio a doble.
    Todos los componentes originales:
    FRAME 06 Hardrock, 6061-T6, Disc only, tig weld, double butted ORE DT, externally machined head tube, forged disc D/O, w/06 derailleur hangar
    REAR SHOCK None
    FORK Marzocchi MZ-3, 100mm, preload adj, 30mm Cr-Mo stanchions, coil/MCU
    HEADSET 1-1/8" threadless, sealed ball retainer
    STEM Specialized Mobius, Alloy, 10 degree rise
    HANDLEBARS Alloy, 38mm rise, 6 degree upsweep, 8 degree sweep, 640mm width
    GRIPS Specialized Enduro, Kraton dual compound
    FRONT BRAKE Avid BB5 Mechanical Disc with 6" roundagon rotor
    REAR BRAKE Avid BB5 Mechanical Disc with 6" roundagon rotor
    BRAKE LEVERS Avid FR-5 alloy two finger
    FRONT DERAILLEUR Shimano M-330 Acera, 31.8mm clamp, bottom pull
    REAR DERAILLEUR Shimano M-410 Alivio, 8spd
    SHIFT LEVERS Shimano M-410 Alivio, 8spd
    CASSETTE SRAM PG-830, 8spd, 11/32
    CRANKSET Truvativ ISO-Flo, Power Spline, alloy, capless bolts
    CHAINRINGS 22 heat treated Cro-Mo/32 heat treated Cro-Mo/42 Cro-Mo
    BOTTOM BRACKET Truvativ Power Spline, 68x113mm, sealed cartridge bearing with double crank stops
    PEDALS 9/16" alloy platform with Cr-Mo spindle
    CHAIN Shimano IG-31
    RIMS SUN DitchWitch, double wall, 36h, eyelets
    FRONT HUB Joy Tech Disc, 36h
    REAR HUB Shimano 475 Cassette Disc, 36h
    SPOKES 2.0mm stainless steel, brass nipples
    FRONT TIRE Specialized Enduro, 26"x2.2", wire bead 30 TPI
    REAR TIRE Specialized Enduro, 26"x2.2", wire bead 30 TPI
    TUBES Specialized 26x2.2", schraeder valve
    SADDLE BG Sport MTB
    SEAT POST Alloy 30.9mmx350/400mm, micro adjust
    SEAT BINDER Alloy collar with Q/R
    Todo funciona a la perfeccion, frenos clavan con un dedo, la horquilla Marzocchi me ha salvado de unas buenas. Bicicleta dura y muy polivalente.
    Mejores componentes (horquilla, bielas, cubiertas...) y bastante mas bonita (opinion personal) que la del 2007.
    Evidentemente está en garantía.
    ---->450 Euros. Vivo en Madrid
  2. DavidVR
    DavidVR Novato
    Madrid - Santander
    te he enviado un mp
