Commençal Supreme Dh VS Scott Gambler Dh 20
Tema en 'DownHill' iniciado por victoriano600, 6 Sep 2007.
  1. victoriano600
    victoriano600 TINAMAR POWER
    23 Feb 2007
    La vega de arriba
    Hola gente, queria saber que bike preferirian, ya que a mi personalmete me encanta la commençal sobretodo por sus componentes y esta scott tiene un cuadro realmente espectacular y llamativo, mientras que sus componentes son un tanto mediocres creo, decidme cual es la que mas merece la pena. En Navidades ya tendre una bike y no querria arrepentirme ajaj.:-D
    73cas1g0VmYY719p49xR4PqaQ7yhRi4h.jpg Precio Scott Gambler Dh 20: 2800€
    Weight
    20.50 kg
    45.15 lbs
    Frame
    New Gambler Alloy 7005
    hydroformed tubing
    DH geometry / ISCG 05 tabs
    adj.headtube for 11/8 and 1.5""
    IDS interchangeable Dropout with
    12mm thru axle / 190-230mm travel
    Fork
    Marzzochi 888 RV 200mm travel
    Coil oil, SSVF, Reb adj.
    Mech. & air preload, 20mm axle,
    Shock (Rear)
    Fox VAN R coil, pro pedal tune
    Reb. adj
    Headset
    VP Cr-Mo cups
    1 1/8"
    Derailleur (Rear)
    SRAM X7 9 Speed medium cage
    Shifters
    SRAM X5
    Trigger Shifter
    Brake Levers
    Avid Code 5 Disc
    Brakes
    Avid Code 5 Disc / 4 piston
    203mm F + R rotor
    Crankset
    Truvative Hussefelt DH 1.1
    36T alloy chainring
    MRP Partycrasher bashguard
    BB-Set
    Truvative HowitzerTM 83mm shell
    MRP SB-3 ISCG Chainguide
    Handlebar
    Scott Pilot FR 1.5
    P.G, 38mm rise, 710mm
    H'stem
    Marzzochi Handlebar Clamp
    55mm ext.
    Pedals
    Shimano PD-M545
    Clipless pedal
    Seatpost
    Scott Pilot FR (telescope)
    no offset
    Seat
    Scott Gambler / 7mm CROMO rails
    soft Tail protection
    Hub (Front)
    Scott Pro 20mm thru axle
    Hub (Rear)
    Sun Ringle Lawwill 12mm thru axle /
    150mm wide
    Chain
    SRAM PC-951
    Cassette
    SRAM PG-950
    12-28 T
    Spokes
    DT Swiss Champion black 2.0mm
    Rims
    Alex Supra BH
    32H / DH disc rim
    Tires
    Maxxis Minion DHF
    front: 26 x2.5 supertacky
    rear: 26 x 2.5 60a
    Wire Bead, 2-ply DH casing,
    butyl insert, 60TPI
    Resized Resized supreme dh 2008.jpg Commençal Supreme Dh: 2550€
    Frame
    Single Pivot with the famous Contact system rocker driven shock system which offers excellent grip in the corners and a solid pedal platform.
    The frame has an adjustable headangle and wheelbase. 150mm rear axle spacing.
    Marzocchi Roco Coil R shock
    Forks
    Marzocchi 888 RCV
    Rear Derailleur
    Sram X7
    Front Derailleur
    C Chainguide
    Shifters
    Sram Trigger X5 right
    Chainset
    Truvativ Ruktion DH w/howitzer interface
    Bottom Bracket
    Truvativ Howitzer
    Chain
    KMC 9s
    Headset
    Tange Fatty MX2 1"1/8
    Stem
    Marzocchi intregrated
    Handlebars
    Commençal 2" oversize
    Front Brake
    Avid Juicy 3 203
    Rear Brake
    Avid Juicy 3 203
    Brake Levers
    Avid Juicy 3 203/203
    Rims
    Sun Rims Single track
    Front Hub
    Commençal disc 20mm
    Rear Hub
    Commençal disc 20mm 12mm
    Spokes
    Stainless 64p 3x lacing
    Tyres
    Maxxis High Roller 26x2.5
    Saddle
    SDG Bel Air
    Seatpost
    Race Face
    Grips
    Commençal Deluxe Lock-on​
  2. german_dh
    german_dh Germán Ferrer
    20 Ago 2007
    Motril Citi
    yo me kedaria con la gambler esta mas wapa y tiene mas recorrido de atras y la comencal esta ya muy vista y la gambler a salio nueva en 2008. con la gambler me kedaria
  3. ogame
    ogame Je suis a
    31 Ene 2007
    Gijón
    a mi me gusta mas la commençal pero bueno eligete el mejor cuadro ya que los componentes son mas faciles de cambiar
  4. victoriano600
    23 Feb 2007
    La vega de arriba
    pues el mejor cuadro supongo que sera el scott
  5. verges
    verges Novato
    12 Oct 2006
    jesus-tortosa
    me gusta mas la scott
  6. victoriano600
    23 Feb 2007
    La vega de arriba
    la horquilla de la commençal es la rcv y la de la scott rv... en componentes la scott no esta fina
  7. x-treme xp deinix
    x-treme xp deinix huevo cosido
    30 Jun 2006
    madrid
  8. jose12
    jose12 Miembro activo
    19 Dic 2006
    yo me quedaria con la commençal...
  9. kionrat
    kionrat lokohombre
    25 Jun 2007
    C O M E N ç A L
  10. chica_freeride
    chica_freeride ★ MiRiaM ★
    24 Jun 2006
    Novelda (Alicante)
    en cuanto a componentes: commençal
    en cuanto a cuadro: scott
    pero como bien dicen por ahi arriba, los componentes te los puedes cambiar (si te lo puedes permitir)
    yo me quedaria con la commençal, que aunque el cuadro no sea tan bonito como el scott, es un buen cuadro. por cierto, que pesa?
  11. victoriano600
    23 Feb 2007
    La vega de arriba
    18.9 Kg entera, creo
  12. jorge dh
    jorge dh Miembro
    22 Jun 2007
    yo me quedo cn la scott me gusta mas
  13. german_dh
    20 Ago 2007
    Motril Citi
    dis ke si jorge la scott esta mucho mas wapa y es mejor
  14. jorge dh
    jorge dh Miembro
    22 Jun 2007
  15. Scottty
    Scottty Hasta el eje...
    23 Oct 2006
    Entre piedres y barro
    La Scott , los componentes se mejoran según se parten, ese cuadro Scott dará que hablar.
    Si yo tubiera dinero...
  16. ADRENALINA
    ADRENALINA Novato
    16 Feb 2006
    yo alquilé por necesidad una commençal dh en Vallnord (tengo una big hitIII) y en comparación a mi bici, puedo decir a favor de la commençal k te haces enseguida con ella, muy agil y demás..., a lo mejor no tan "tragona", pero la metes enseguida en la curva, etc... aaaah!!! y muy ligera!!!!
  17. victoriano600
    23 Feb 2007
    La vega de arriba
    de la commençal solo me llegan elogios
  18. bokeronX
    bokeronX Miembro
    25 Ago 2006
    Andalucía
    sinceramente pienso ke opinar d una bike ke no ha probado nadie, es imposible decidirse,
    solo cabe opinar a nivel estetico... la scott wapa... pero alguien sabe como funciona????????????
    creo ke el sistema es parecido a la ramson????
    el sistema ke ha usado scott en nitrus en mi opinion es KK... a saber como funciona la bike.. ke es lo importante:laserkill
  19. candongo free
    candongo free Miembro Reconocido
    22 Dic 2005
    Graná
    solo tienes que ver que el diseño del cuadro commencal lleva 4 años casi inalterable, solo por una razon: FUNCIONA DE MARAVILLA, si no que se lo pregunten a Cedric porque no quiso retocar nada cuando llego a commencal con la mision de mejorar el DH...
    Como gustos esta claro que cada uno esteticamente le gustará uno u otro pero con funcionamiento para DH 100% con 180/200mm vas de sobra.
    Yo no he probado el nuevo Scott pero tengo un Commencal Supreme DH 05 y en comparación con los antiguos Scott, estos son una jaca, altos y cortisimos. Lo dicho para mi sin probar estos ultimos me quedo con el Commencal.
  20. victoriano600
    23 Feb 2007
    La vega de arriba
    gracias por el consejo cadongo
