Opinion Sobre La Spec Rockhopper!!!
Discussion in 'Bicis y componentes' started by burnubu, Feb 1, 2008.
  1. burnubu
    burnubu Miembro
    Hola todos!
    creo que me he enamorado de esta bici... y queria saber que opinion de ela teneis los que la teneis..y los que no tambien!!
    en concreto es la rockhopper comp disc 2008
    muchas gracias a todos po adelantado!! y a dar pedaleeeees!!!:saltarin
    ahh!! se me olvidaba....las caracteristicas son: (en ingles, lo siento)
    CUADRO M4 manipulated alloy frame, butted ORE DT, forged dropouts w/ replaceable 98954020 alloy hanger, disc only
    HORQUILLA RockShox Recon Race SLite, 100mm, 32mm alloy stanchions and steerer, Turn Key damper w/ lockout and reb. adj., 13-15" standard spring, 17-23" "stiff" spring, disc only
    DIRECCION 1 1/8" threadless
    POTENCIA Specialized 3D forged alloy, four bolt, 31.8mm, 7 degree rise
    MANILLAR Specialized alloy butted 31.8mm XC rise w/ graphic, 640mm wide, 8 degree back, 8 degree up sweep
    CINTA / PUÑOS Specialized Enduro, dual density Kraton
    FRENO DELANTERO Avid Juicy 3 SL, hydraulic, 6" G2 clean sweep rotor
    FRENO TRASERO Avid Juicy 3 SL, hydraulic, 6" G2 Clean Sweep rotor
    PALANCAS DE FRENO Avid Juicy 3 SL, hydraulic
    DESVIADOR Shimano Deore FD-M530, 34.9mm clamp
    CAMBIO Shimano XT RD-M771, SGS cage
    MANDOS DE CAMBIO Shimano Deore SL-M530 trigger
    CASETE/RUEDA LIBRE Shimano HG-50, 9-speed, 11-34t
    CADENA KMC X9, 1/2" x 3/32" w/ reusable Missing Link
    PEDALIER Shimano FC-M521, Hollowtech, replacable rings with alloy outer, Octalink spline
    PLATOS 44A/32S/22S
    CAJA PEDALIER Shimano BB-ES25, Octalink spline, cartridge bearing, 68 x 118mm for 50mm chainline
    PEDALES Shimano 505 SPD, reflectors and cleats
    LLANTAS DT-Swiss 445D, 26", double wall disc, pin joint, eyelets, 28h front, 32h rear
    BUJE DELANTERO Specialized Hi Lo disc, 28h, CNC flange and disc mount, polished races, alloy QR
    BUJE TRASERO Specialized Hi Lo disc, cassette, 32h, CNC flanges and disc mount, polished races, alloy QR
    RADIOS 1.8mm (15g) stainless, alloy nipples, black
    NEUMATICO DELANTERO Specialized Fast Trak LK Sport, 26x2.0", 60TPI, wire bead
    NEUMATICO TRASERO Specialized Fast Trak LK Sport, 26x2.0", 60TPI, wire bead
    CAMARAS Specialized schraeder valve
    SILLIN Specialized Indie XC Sport, kevlar sides, Cr-Mo rail, 143mm width
    TIJA DE SILLIN Specialized butted alloy, two bolt micro adjust head, 30.9mm
    ABRAZADERA SILLIN Specialized alloy w/ QR, brass washer
    PRECIO: +- 1000€
  2. burnubu
    burnubu Miembro
  3. asics
    asics Alma sana in corpore sano
    Mao
    a mi me parece una super bici, tiene un cuadro mucho mejor que el de hace dos años es un M4 y antes era un A1. es mas ligero y absorbe mejor.
    creo que por ese precio esta muy bien. yo la tuve y la tengo ahora otra vez y estoy encantado con ella.
  4. ARVICENTE
    ARVICENTE Miembro activo
    Que te voy a decir yo.
    Tienes bici para rato, eso sí, si lleva el mismo manillar que llevaba la del 2007 es un hierro (400 gr) por lo demás esta todo muy bien, sobre todo el cuadro, que por cierto es lo único que queda de la mía, je, je. ;-)
  5. PLANIYO
    PLANIYO QUERER ES PODER
    Zaragoza
    mu buena relacion calidad precio sobre todo por el cuadro, luego si quieres puedes ir mejorando pero ya tendras una base q es el cuadro es bonita es blanca
  6. ARVICENTE
    Ja, ja no podiamos faltar ni Planiyo ni yo en un post de Spe. :qmeparto
    He visto lo que te a pasado con los CB pero estaba currando y no he podido postear, que putada. Yo soy de Shimano :mrgreen:
    Burnubu pillatelá tio, no lo dudes, no te vas a arrepentir.
    Si además a sido amor a primera vista no? :love
  7. ARVICENTE
    Por cierto Planiyo te pregunté sobre tus cubiertas en el post de mi bici.
    Pero has pasado de mi. :crybaby
  8. burnubu
    burnubu Miembro
    ya veo que estais encantados.
    creo que leyendo estos comentarios, aun me gusta mas...
    alguien mas que pueda decir algo?
