Vendo Specialized Safire Comp muy barata, está nueva!
Discussion in 'BTT - Con Suspensión Trasera' started by Buba, Jun 26, 2008.
  1. Buba
    Buba Miembro
    La Coruña
    Vendo Specialized Safire fsr comp, color rosa negro. Muy pocos dias de uso. Está impecable.
    1.500 Euros (nueva cuesta 2.500) Talla M
    CARACTERÍSTICAS:
    CUADRO All new Safire FSR M5 manipulated alloy frame w/ Women's specific ORE TT/DT, Designs for Women geometry, sealed cartridge bearing pivots, DMD Direct Mount F. Der, replaceable derailleur hanger, disc only, 120mm travel
    AMORTIGUADOR Fox Triad, custom on-the-fly 3-position switch 1) lock out 2) Open 3) ProPedal pedal assisting damping, adjustable rebound, 7.25x1.75"
    HORQUILLA Fox Float 120 RL, 120mm travel, rebound/compression adjust, lock out, alloy steerer
    DIRECCION 1 1/8" threadless, alloy cups w/ 10mm insertion, sealed cartridge bearing
    POTENCIA Specialized adjustable rise, 31.8mm clamp, 3D forged w/CNC finish
    MANILLAR Specialized XC low rise 31.8mm bar, 6066 butted alloy, 6 degree up, 8 degree backsweep, 620mm wide
    CINTA / PUÑOS Specialized Womans MTB, dual density
    FRENO DELANTERO Custom Avid Juicy 5 SL, hydraulic disc, 160mm rotor
    FRENO TRASERO Custom Avid Juicy 5 SL, hydraulic disc, 160mm rotor
    PALANCAS DE FRENO Custom Avid Juicy 5 SL, hydraulic disc
    DESVIADOR Shimano M581 LX, DMD, top swing, dual pull
    CAMBIO SRAM X-9, 9-speed, mid cage
    MANDOS DE CAMBIO SRAM X-7, aluminum 9-speed trigger
    CASETE/RUEDA LIBRE Shimano HG-50, 9-speed, 11-34t
    CADENA SRAM PC-971 w/ Power Link
    PEDALIER Shimano A/A/S 2pc custom
    PLATOS 22S/32A/44A, 4 bolt 104/64mm
    CAJA PEDALIER Shimano M542, 2pc custom for Specialized
    PEDALES Crank Brothers Smarty custom for Specialized
    LLANTAS DT Swiss custom for Specialized X420, 24mm w/ eyelets, 28/32h
    BUJE DELANTERO Specialized Hi Lo disc, 28h CNC flange and disc mount, sealed cartridge bearing, 9mm DT RWS alloy QR
    BUJE TRASERO Shimano custom M525SL hub for Specialized, 32h, alloy QR
    RADIOS DT Swiss 1.8mm stainless, alloy nipples
    NEUMATICO DELANTERO S-Works The Captain 26x2.0", 120 TPI, tubeless ready aramid bead, dual compound
    NEUMATICO TRASERO S-Works The Captain 26x2.0", 120 TPI, tubeless ready aramid bead, dual compound
    CAMARAS Specialized Ultralite, .6mm, presta
    SILLIN Specialized Women's Ariel MTB, hollow Cr-Mo rails
    TIJA DE SILLIN 2019 butted alloy, two bolt non-setback, 30.9 x 350/400mm
    ABRAZADERA SILLIN Alloy collar w/ QR, 34.9mm clamp ID
  2. Torpedomaster
    Torpedomaster de todos los santos
    Bonita máquina
  3. Torpedomaster
    ¡qué pequeño es el mundo!: le cuento a mi chica que me había interesado por tu bici pero que la faena es que no le valía la talla y me dice que cree que coincidisteis y hablasteis en la quedada de chicas de Rivas. Ella es P-Pod y como te decía en un mp llevaba una Myka azul
    Bueno, te lo cuento por aquí y así subimos el anuncio
  4. Buba
    Buba Miembro
    La Coruña
    Hola!
    Pues si, seguramente que nos viésemos por Rivas, yo era la chica de la sx, la bici de four cross, soy de la coruña. Nunca había visto tantas chicas juntas!!! Mándale saludos.
    Quizás tengo alguna foto suya, voy a mirar, si la encuentro os las envío.
    Eva
  5. RoyBatty02
    RoyBatty02 Miembro
    Menuda bici!!! Suerte con la venta!!
  6. el_biker
    el_biker TRAIN HARD OR GO HOME
    Pontevedra, Galicia
    Dios que guapa!
  7. palangui
    palangui PYRENEAN MAN
    Andorra
    Jajaja mi novia se ha enamorado de esa bici...
    Te la cambio por un gt i-drive jeje
  8. Buba
    Buba Miembro
    La Coruña
    Lo siento, no la cambio, la tengo a la venta. Estírate y regálasela a tu chica!!! Hay que cuidar a las mujeres!! jejejeje Un saludo,
    Eva C.
  9. m_cadi
    m_cadi Miembro
    Buenas, me interesa tu bici, dime para que altura es porque supongo que las tallas no van igual que en las de chico.
    Soy de Santander. En caso de valerme me interesaría probarla antes de comprarla
    Gracias y un saludo
  10. rachelovic
    rachelovic Miembro Reconocido
    Hola Buba.. aquí en valencia conozco una chica que puede estar interesada ¿puedes decirme cuanto pesa?
    gracias
  11. Buba
    Buba Miembro
    La Coruña
    ok, la peso y te digo
  12. Bufalo82
    Bufalo82 Novato
    Preciosa de verdad!Mi novia casi le pega algo cuando la ve,lastima que este en proceso de comprarme la mia y no tenga dinero ni pa la una ni pa otra.
    Muchas suerte con la venta!!
  13. Buba
    Buba Miembro
    La Coruña
    La safire pesa 11.95 k.
  14. Fanniky
    Fanniky Novato
    Almoradí Alicante
    Jo que pena! yo que me acabo de comprar bici... y esa era una de las que me gustaba...
  15. riky-placentino_rider
    riky-placentino_rider destroza trialeras
    wui bonita jej,,esas bikes ENAMORAM... SALUDOS
  16. ribitxu
    ribitxu mutanbiker
    barcelona-bilbo
    q wapa q esta la bici!!q pena q m acabo d comprar la mondraker foxy...y d moment como no m a tocao la loteria no m da pa mas!!je je je suerte con la venta!!!
  17. MiriaM
    MiriaM zupervaka Moderador ForoMTB
    no quiero mirarla, no quiero mirarla...
    que no me caben mas bicis en casa...
    XD
  18. pablobeuchat2005
    pablobeuchat2005 Miembro Reconocido
    Galicia
    pero no tenias una specialized roja:comor3
    venga suerte con la venta asi tb te lo subo:mrgreen:
  19. kani_lady
    kani_lady Leleleee
    Tarragona
    BUf.. me enamorado... xD
    Si en septiembre-octubre sigue por aki, te la compro! xD Que ahora... voy mal de pasta jeje
    Porcierto mido 1.75... no se si seria mi talla :s
  20. lagartopower
    lagartopower Novato
    Quería saber si ya vendiste la bici. Y si no la vendiste, es por si la podría ver.
