Casi a estrenar , vendo por no usar , horquilla aumentada a 180 mm de recorrido. 1700 EUROS CUADRO SX Trail de aluminio M5 Premium, tubo superior y diagonal ORE, tubo horizontal forjado, diseño con bajo centro de gravedad, pivotes de giro con rodamientos sellados, anclaje ISCG, patilla reemplazable, protector de cambio, 170mm de recorrido. AMORTIGUADORFox DHX 4.0 muelle 7.875x2.25", ajuste de rebote y ProPedal Muelle: 550 HORQUILLARockShox Domain 318 muelle. 180mm, ajuste de compresión y rebote, tubo de dirección variable de 1 1/8 a 1.5" DIRECCIÓN 1-1/8" to 1.5" Threadless, alloy, cartridge bearing POTENCIASpecialized Aggro stem, 35mm extension, OS 31.8, 4-bolt, forged MANILLARSpecialized Enduro mid rise bar, 6066 alloy, 31.8mm, 6 degree up, 9 degree backsweep, 660mm wide PUÑOSSpecialized thin lock on grip, alloy bar ends FRENO DELANTEROCustom Avid Elixir R, hydraulic disc, reach adjust, metallic pads, 203mm rotor FRENO TRASEROCustom Avid Elixir R, hydraulic disc, reach adjust, metallic pads, 185mm rotor PALANCAS DE FRENOCustom Avid Elixir R Hydraulic, tool-less adj. reach DESVIADORShimano M660 SLX, DMD, top swing, dual pull CAMBIOSRAM X-O, 9-speed, mid cage MANDOS DE CAMBIOSRAM X-5, trigger, 9-speed CASETEShimano HG61, 9-speed, 11-34t CADENASRAM PC-971, 9-speed w/Power Link PEDALIERTruvativ Stylo, 170mm, w/ Gamut Shift chain guide PLATOS24A x 36A w/ Gamut guard CAJA PEDALIERTruvativ Stylo, outboard bearing PEDALESSpecialized Lo-Pro alloy LLANTASCustom DT Swiss F550, 30mm, 32h BUJE DELANTEROSpecialized Hi-Lo disc, 20mm thru axle, 32h BUJE TRASEROSpecialized bolt on, 135mm, hollow 10mm Cr-Mo axle w/ RD guard RADIOSDT Swiss Champion 2.0mm stainless, black, brass nipples NEUMÁTICO DELANTEROSpecialized Clutch SX 26x2.3", 60 TPI, aramid bead, cap ply, soft dual compound NEUMÁTICO TRASEROSpecialized Clutch SX 26x2.3", 60 TPI, aramid bead, cap ply, soft dual compound CÁMARAS Specialized 26x2.3", presta SILLÍN Specialized Enduro, 8mm Cr-Mo rails, SL foam TIJA DE SILLÍN6061 alloy, black, 30.9 x 300mm ABRAZADERA DE SILLÍN7050 hard annodized alloy collar w/ QR, 34.9mm clamp ID, black
El sabado estaré en La Pinilla viendo el Campeonato de Madrid de descenso y llevaré la bici, si alguien está interesado en verla que me lo comente.
gerx, sigo a la espera de vender mi cuadro, el comprador se echo atras, estaremos en contacto, un saludo
