___las "tope de gama 08" de las principales marcas___
Tema en 'DownHill' iniciado por mnsport, 6 Feb 2008.
con cual os quedariais ???? y qien quiera , por que???
  1. Marzocchi 888 Rc3 WC 2008
    55 voto(s)
    37,7%
  2. Marzocchi 888 ATA WC 2008
    14 voto(s)
    9,6%
  3. Rock Shox Boxxer WC 2008
    50 voto(s)
    34,2%
  4. Fox 40 Rc2 2008
    16 voto(s)
    11,0%
  5. Manitou Travis triple Intrisic 2008
    11 voto(s)
    7,5%
  1. mnsport
    mnsport ScReAm member
    11 Ago 2006
    bueno , ago esta encuesta para haver cual es la favorita y ver diversas opiniones sobre cada una .
    ___888 rc3 wc___:
    -200mm Travel
    - RC3 Volume Adj.
    - One Side Ti Spring
    - Aluminum Steer Tube
    - 38mm Nickel Coated Alloy Stanchions
    - 8” Post Mount (Max Disc 9”)
    - 20mm Axle
    -3.633 gr/8.00 lbs.
    ___888 ata wc___:
    - 160mm to 200mm Adj. Travel
    - RC3 Volume Adj.
    - ATA (Air Travel Adjust)
    - Air Spring
    - 20mm Axle
    -3.150 gr/6.94 lbs.
    ___rock shox boxxer wc___:
    -Adjustability: External rebound, Floodgate, external compression and internal high speed shim stack; Air pressure via a single Schrader valve
    -Travel: 203mm
    -Axle Type: Maxle 20mm through axle
    -Steer Tube Diameter: 1 1/8" Butted Aluminum
    -Weight: 2676g / 5.9 lb
    -Color: Athena White
    -Brake Mount Type: Disc Only
    -Crown: Tall - Forged 7050 T-6 aluminum, direct mount stem compatable
    __fox 40 rc2__:
    -wight: 3090g / 6,83 lb
    -travel:203mm
    -spring:titanium
    -adjustments:
    .low speed compression
    .high speed compression
    .coil spring preload
    .rebound
    ___manitou travis triple intrisic ___:
    Travel: 180mm, 203mm
    • Weight: 180mm (3521) grams, 203mm (3557) grams
    • Damping: Air Cartridge IFP Intrinsic
    • Adjustment: Rebound, Compression, Cartridge Air
    • Lubrication: Open Oil Bath
    • Spring: Coil
    • Casting: 34 Magnesium RA with Paraboloic Arch
    • Stanchions: 34mm Alu
    • Steerer: Alu
    • Crown: Integrated Handlebar Clamp
    • Axle: Hex Lock Thru-axle
  2. EL_ESPECIAL-MONDRAKER
    EL_ESPECIAL-MONDRAKER - FUTBOL Y + DH
    22 Mar 2005
    la rc3 wc sin dudarlo es la mas fiable de todas las de la lista
  3. mochilo
    mochilo Only Raw
    11 Sep 2007
    Aquí y ahora
    yo, soy de marzocchi y de muelle jaja asi k lo tengo claro
  4. FaLToLR
    FaLToLR Sera Posible
    28 Mar 2007
    Aguilas, ( Murcia )
    =mente mochilo
  5. Pedrusco
    Pedrusco Novato
    2 Oct 2005
    Flix (Ribera D'ebre)
    Yo llevo la 888 ATA WC en la 224 y la verdad es que estoy encantado. Va super bien y pesa bastante menos que la Rc3
  6. GuillaN
    GuillaN Miembro activo
    28 Ago 2006
    O Grove / Vigo.
    Quita tio... Donde esté una Boxxer!:mrgreen:
    Saludos!
  7. oskar M
    oskar M rider
    7 Ene 2007
    k dices donde este una marzochi que se quiten la boxxer
  8. chimy
    chimy freerider gallego
    17 Ene 2006
    nigrán(pontevedra)
    estamos en lo de toa la vida, yo bajo mi punto de vista marzocchi para es lo mas hacertado, por rijidez y por mantenimiento y perfecto funcionamiento, donde peca es en el peso, boxer desde que la conpro el grupo srran dio y esta dando pasos de gigante, funciona genial, pero para la puesta a punto y mantenimiento tines que saber lo que haces. un salud
  9. harl-adri-harl
    harl-adri-harl Baneado
    30 Oct 2006
    vivo con tu **** madre
    marzocchi sin duda alguna :eek:la2
  10. BH3_Uri
    BH3_Uri Miembro
    4 Nov 2007
    barna
    marzocchi siempre
  11. DAVO
    DAVO Miembro activo
    13 Jul 2005
    Al norte, frente al mar
    Buff la decision de siempre! Por tacto y por fiabilidad, Marzocchi!! la 888 Rc3 World Cup va de miedo y pesar... pues que quereis que os diga que no la veo tan pesada como dicen!!
  12. ukukus
    ukukus Malosera...
    22 Nov 2007
    Valdeorras
    *****....estas fuerte Davo, estos de la mariña si que valen y no los de Bilbao jejejee.
    la verdad que pesa mas que una boxxer y se nota de *******, lo que pasa es que te acabas acostumbrando....eso si buen tacto y 0 problemas
  13. ##iban##
    ##iban## Miembro Reconocido
    2 Jul 2007
    Girona
    Bueno pues no sé que quereis que os diga yo tengo tantas dudas que para votar por una...... me cuesta un montón, de momento he pedido un 888 ata WC a ver como funciona, espero acertarla que no son varatas. Por lo tanto mi voto va para marzocchi, muelle por seguridad y la de aire con alguna duda por peso. Y si la fox no fuera tan cara..... Eso si, sin desmerecer ninguna de las demas que seguro funcionan de coña.
  14. "kamikaze"
    "kamikaze" X3me Biker
    11 Ene 2007
    Málaga
    Si fuera SOLO para competir -- Boxxer wc
    Para un uso normal (entrenamiento, alguna competicion...) --> Marzocchi rc3wc
    La ata, en la comparativa de bikes de dh en solobici, no hablan muy bien de ella... aunque supongo que tambien sera un papinon de horquilla.
  15. DAVO
    DAVO Miembro activo
    13 Jul 2005
    jajaja!! El cocido de mi abuela que es la leche!!!! XD
    La verdad que tengo curiosidad por probar la boxxer Wc, tiene que ir muy bien, pero yo por ahora no me quejo! Ya tengo de mas para mi!
  16. gerardrev
    7 Dic 2004
    Encima d la bici
    boxxer les da mil vueltas a todas.
  17. Razorvfv
    Razorvfv Miembro
    11 Feb 2007
    normal arriba las boxxer
  18. agustinitoto
    agustinitoto Tactic Racing
    23 Oct 2006
    si te va la competicion de verdad boxxer manda,siempre i cuando la trates con cariño la cuides i la mimes.
  19. victoriano600
    victoriano600 TINAMAR POWER
    23 Feb 2007
    La vega de arriba
    fox.... mira el peso
  20. mnsport
    11 Ago 2006
    bueno parece que la cosa anda reñida , entre la boxxer wc y la 888 rc3 , pues yo me quedo con FOX !!! , tacto muelle y aceite la mas ligera con este sistema , funcionamiento impecable y estetica bestial.
