ayuda para comprar bicicleta doble
Discussion in 'Tiendas y Compras. ¿Qué comprar y dónde?' started by chopero, Aug 19, 2011.
  1. chopero
    chopero Colecciones
    Toledo
    Hola,no se por cual decidirme de estas.Espero opiniones!!
    Specialized Epic comp 2012[​IMG]
    Cuadro: M5 alloy, fully manipulated frame w/ ORE DT/TT, gussetless TT (S/M), tapered HT, 135mm dropouts, sealed cartridge bearing pivots, replaceable derailleur hanger, 100mm travel
    Horquilla: RockShox Reba RL, tapered alloy steerer, LO and reb adj. standard drop-outs, 100mm travel
    Amortiguador: Fox/Specialized remote Mini-Brain w/new 2012 tune, inertia valve, w/ Brain Fade adjust, 187x47mm
    Ruedas: Custom DT Swiss X420SL, 24mm w/ eyelets, 28/32h
    Cubiertas: S-Works Fast Trak, 120 TPI, 2Bliss ready aramid bead, dual-compound, 26x2.0"
    Cambio: SRAM X9, 10-speed, mid cage
    Desviador: SRAM X7, 10-speed, S3 direct mount for DMD, bottom-pull
    Sistema de Cambio: SRAM X7, 10-speed, aluminum trigger, w/MatchMaker clamp
    Bielas: Custom SRAM S-1250, 7050 alloy arms, 10-speed XC double, GXP spindle, S: 170mm, Others: 175mm
    Cassette: SRAM PG-1030, 10-speed, 11-36t
    Pedales: Resin Test Ride Pedals with toe clips, CEN std.
    Sillín: Specialized Body Geometry Phenom Comp, hollow Cr-Mo rails, 143mm width
    Tija de Sillín: 2014 butted alloy, single bolt setback, 30.9mm, 400mm
    Manillar: Specialized XC flat, 2014 butted alloy, 680mm wide, 8º back sweep, 31.8mm
    Potencia: Specialized XC, 3D forged alloy, 4-bolt, 31.8mm clamp, adjustable rise, S: 75mm, M: 90mm, L: 105mm, XL: 105mm
    Dirección: 1-1/8 and 1-1/2" Threadless, Campy style upper with 1-1/2" lower, cartridge bearings
    Frenos: Custom Avid Elixir 7 SL, hydraulic disc, alloy backed semi-metallic pad, 160mm HS-1 rotor
    Specialized Epic comp carbon 2011 [​IMG]
    Cuadro: FACT 9m carbon front triangle, FACT IS construction, gussetless TT S/M, M5 aluminum chainstays & seatstays, tapered HT, carbon PF-30 BB, 135mm drop-outs, sealed cartridge bearing pivots, replaceable derailleur hanger, 100mm travel
    Horquilla: RockShox Reba RLT, tapered alloy steerer, compression and rebound adj. LO w/external floodgate adj., standard drop-outs, 100mm travel
    Amortiguador: Fox/Specialized remote Mini-Brain, inertia valve, w/ Brain Fade adjust, 187x47mm
    Cubiertas: S-Works "The Captain", 120 TPI, 2Bliss ready aramid bead, dual compound, 26x2.0"
    Cambio: SRAM X.9, 10-speed, mid cage
    Desviador: SRAM X.7,10-speed, S3 direct mount for DMD, bottom pull
    Sistema de Cambio: SRAM X.7, 10-speed, aluminum trigger
    Bielas: Custom SRAM S-1250, 7050 alloy arms, 10-speed XC double, GXP spindle, S: 170mm, others: 175mm
    Cassette: Shimano HG81, 10-speed, 11-36t
    Sillín: Specialized BG Phenom Comp, hollow Cr-Mo rails, 143mm width
    Manillar: Specialized XC low-rise bar, 2014 butted alloy, 660mm wide, 8 degree back sweep, 6 degree up, 31.8mm
    Dirección: 1-1/8 and 1.5" Threadless, Campy style upper with 1.5" lower, cartridge bearings
    Frenos: Custom Avid Elixir R SL, hydraulic disc, tool-less reach adjust, alloy backed semi-metallic pads, stainless hardware, G3 Clean Sweep rotor, S/M: 160mm, L/XL: 185mm rotor
    Cannondale Scalpel 3 2011 [​IMG]
    Cuadro:
    Scalpel BallisTec Hi-MOD full carbon 80 mm Zero Pivot SAVE BB30
    Horquilla: Lefty Speed alloy PBR and Solo Air OPI
    Amortiguador:
    RockShox Monarch RT3 custom tune
    Ruedas: DT Swiss XCR 1.7
    Cubiertas: Schwalbe Racing Ralph PaceStar 2.1”
    Cambio: Shimano XT
    Desviador: Shimano SLX
    Sistema de Cambio: Shimano SLX display
    Bielas: FSA Afterburner 386 BB30 42/27t
    Cassette: Shimano SLX 11-36t 10sp
    Pedales: CrankBrothers EggBeater 1
    Sillín:
    Cannondale Stage crmo rails
    Tija de Sillín:
    Manillar: Cannondale C2 “zero rise”
    Potencia:
    Cannondale OPI adjustable stem/steerer 3D forged
    Dirección:
    Cannondale Si HeadShok
    Frenos: Avid Elixir R
  2. odrvw
    odrvw Miembro Reconocido
    Sin duda alguna me quedo de lejos con la Cannondale Scalpel.
  3. chopero
    chopero Colecciones
    Toledo
    no hay mas opiniones??,la scalpel la descarto,puesto que se me va de precio,en cuanto alas specialized cual pensais que es mejor?
