DUELO!!! Specialized FSR xc Comp VS. Trek Fuel EX6
Tema en 'Tiendas y Compras. ¿Qué comprar y dónde?' iniciado por Dr_kilerin, 12 Mar 2007.
  1. Dr_kilerin
    Dr_kilerin Novato
    18 Dic 2006
    Pues eso, haver por qual me decido:
    SPECIALIZED FSR XC COMP:
    -Cuadro FSR M4 butted frame w/ ORE downtube, sealed cartridge bearing pivots, replaceable derailleur hanger, two sets of water bottle bosses, disc only, 100mm travel
    -Horquilla Rock Shox Recon 335, 100mm, fixed coil, lock out, turnkey damper, ext rebound adj, alloy steerer
    -Amortiguadores X Fusion 02RC, Specialized tuned, rebound/compression adjust w/ lock out, 7.0x1.6"
    -Llantas Mavic X117 Disc, 26", 32h, black, presta valve
    -Bujes Front: Specialized disc, loose ball bearing, high/low flange, 32h. Rear: Shimano M-475L disc, 32h, 8/9-speed, alloy QR.
    Radios 1.8mm stainless, black, brass nipples
    -Cubiertas Specialized Resolution 26x2.0", 60TPI, aramid bead, dual compound
    -Pedales Shimano 505 SPD
    -Bielas Shimano FCM-442-8, Octalink Spline, 9-speed, replaceable rings w/ alloy outer. 22s/32s/44A 4mm thick outer, 4 bolt 104/64mm
    -Cadena Shimano HG73
    -Piñones Shimano HG50, 9-speed, 11/34t
    Eje de Pedalier Shimano ES-25 Octalink Spline, 68mm shell, 118mm spindle, 50mm chainline
    -Desviador Shimano FD-M530, Deore, top swing, duall pull, 34.9mm clamp
    -Cambio Shimano M-751 Deore XT, long cage, standard spring
    -Manetas de cambio Shimano SL-511 Deore, 9-speed
    -Manillar Specialized XC low rise, butted alloy, 640mm wide, 6 degree up, 8 degree backsweep
    -Potencia Aluminum, 7 degree rise, OS 31.8, 4 bolt, black
    Dirección 1 1/8" threadless, black steel cups, loose ball bearings w/ seals
    -Frenos Avid Juicy 3, hydraulic disc, G2 Clean Sweep
    -Manetas de freno Avid Juicy 3 hydraulic
    -Sillín Specialized BG MTB
    -Tija del sillín 6061 alloy, black, 30.9 x 350/400mm
    TREK FUEL EX 6:
    Cuadro
    ZR 9000 Alloy main frame w/100mm travel
    Horquilla
    RockShox Reba SL w/positive and negative air pressure, Motion Control, rebound, compression, lockout, 100mm
    Amortiguador
    RockShox MC3.3 w/air pressure, 3-position Motion Control, rebound
    Ruedas
    Shimano Deore LX disc hubs; Bontrager Ranger rims
    Bielas
    Shimano Deore LX 44/32/22
    Manetas de Cambio
    Shimano Deore XT
    ?¿¿?¿?¿?¿?¿?¿? SEÑORES/AS SE ABREN LAS APUESTAS ¿??¿¿?¿?¿?¿?¿?¿?¿?
