Ktm Speed Rc 3.0
Tema en 'Tiendas y Compras. ¿Qué comprar y dónde?' iniciado por taotao, 20 May 2008.
  1. taotao
    taotao Miembro
    12 Ago 2007
    Lleida
    Buenas tengo un colega que se quiere comprar una doble y se ha mirado esta KTM, se la dejan por 1700€. Que os parece? Que tal la bici calidad precio? Os pongo una fotito y como va equipada...
    KTM SPEED RC 3.0 FULL SUSPENSION MOUNTAIN BIKE
    Where the model selected is not a stock item or is currently sold out, we aim to supply the bike to your door within 14 days. This is subject to the availability from the KTM Austrian Cycle Factory.
    Frame: SPEED RC 3.0 (816), material: aluminium 6061, single pivot linkage, fully adjustable seatpost, sealed grooved ball bearing for integrated head set
    Rear Shock: RS Monarch 3.3, Travel: 110/90, S: Air positive, D: Motion Control, A: ext. Rebound, 3 pos. Hebel, Floodgate
    Fork: Rock Shox Reba Race, Travel: 100, S: Dual Air Spring, D: Motion Control, A: ext. Reb.& Floodg. & Compr, Lockout with Pop-Lock Lever
    Rear Derailleur: Shimano Deore XT s, 9-fold, Top Normal - conventionel "Shadow-Design"
    Shifting Levers: Shimano Deore XT, gear lever RapidFire - Instant-/ Multi-/ Two-Way-Release
    Front Derailleur: Shimano Deore XT, Down Swing, Dual Pull
    Chain: Shimano Deore XT, gearchain HG 9-fold Type
    Casette Sprockets: Shimano Deore XT 11-34, sprocket cassette 9-fold - 3-piece aluminium alloy carrier
    Gear Ratio: 11 - 13 - 15 - 17 - 20 - 23 - 26 - 30 - 34
    44 - 32 - 22
    Crankset: Shimano Deore XT, chain set - Hollowtech II, with integrated hollow axle
    Bottom Bracket: Shimano cartridge, cartridge-bearing
    Brake Levers: Magura Louise 08 Disc BAT, aluminium lever, BAT = distance and pressure adjustable
    Brake: Magura Louise 08 Disc, hydraulic disc brake
    Front Hub: Shimano Deore XT Disc 6L, aluminium hub with quick-release, 6-holes mounting
    Rear Hub: Shimano Deore XT Disc 6L, aluminium cassettehub with quick-release, 6-holes mounting
    Spokes: DT Competition 2.0/1.8
    Rims: Mavic XM-317 Disc, aluminium double wall rim 26", with eyelets, 32 holes
    Tyres: Schwalbe Nobby Nic 2.1, tyres 26" x 2.1, Black-Skin Evolution, foldable
    Head Set: Ritchey Comp A-Head, A-Head Zero-Logic System, integrated, carbon spacer
    Stem: Ritchey Comp, A-Head-stem, 6°, 4-screws-clamping
    Handle Bar: Ritchey Comp Lowriser 620/18, Lowriser-handle bar, 620mm - 18° Rise
    Pedals: Shimano M520, SPD-Click-pedal
    Saddle: Selle Italia XR TransAm (KTM)
    Seatpost: Ritchey Comp 2-bolt, aluminium shaft and aluminium clamping - 2 bolts, D: 27.2
  2. expeedy
    expeedy Expeedy
    30 Oct 2007
    Zaragoza
    ¿si la comparamos con lapierre 310 ¿que diferencia hay entre la fox rl 100 y la reba??
    ¿como influye ele distinta disposición del basculante?
    yo busco bici nueva y estoy entre las dos.
    up,up
  3. er_torero
    er_torero ENCARGADA LA TREK 8500
    12 Oct 2008
    Bueno, yo he mirado y he oido, que hay Trek's dobles, por un precio muy bueno. Y las has sacado bastante bonitas.
  4. expeedy
    expeedy Expeedy
    30 Oct 2007
    Zaragoza
  5. expeedy
    expeedy Expeedy
    30 Oct 2007
    Zaragoza
    ¿Alguien la tiene?
  6. er_torero
    12 Oct 2008
    expeedy, la verdad yo no se para que te como la cabeza para que te pilles la Trek, si tu amigo se quiere pillar una KTM, pues una KTM.
    Estos son sus componentes y te explico un poquillo lo que tiene:
    Cuadro, ALU 7005 DOUBLE BUTTED
    Amortiguación, ROCK SHOX ARIO
    Horquilla, ROCK SHOX REBA
    Dirección, RITCHEY COMP INTEGRE
    Frenos, SHIMANO XTR
    Manetas Freno, SHIMANO DEORE LX
    Mandos, SHIMANO DEORE LX
    Pedales, SHIMANO SPD
    Bielas, SHIMANO DEORE XT
    Cubiertas, SCHWALBE NOBBY NIC
    Llantas, MAVIC XM 317 DISC
    Bujes, SHIMANO DEORE LX
    Potencia, RITCHEY COMP
    Manillar, RITCHEY COMP
    Desviador, SHIMANO DEORE XT
    Cambio, SHIMANO DEORE LX
    Sillín, SELLE ITALIA XR
    Tija Sillín, RITCHEY COMP.
    Bueno tiene unos componentes de la *****, son dentro de lo que cabe bastante buenos. Las bielas son shimano Deore XT, la horquilla una Rock Shox Reva, y las cubiertas de las ruedas unas SCHWALBE. Yo creo que esta muy bien, dile que se la pille.
  7. expeedy
    expeedy Expeedy
    30 Oct 2007
    Zaragoza
    gracias socioooooo cuanta paciencia tienes........:rally
  8. Farnit
    Farnit Baneado
    8 Oct 2006
    Granada
    A mi personalmente me gusta más la KTM Score RC 4.0 (1600€) que la Speed 3.0 que tú dices
  9. expeedy
    expeedy Expeedy
    30 Oct 2007
    Zaragoza
    La que muestras es del 2009 mientras que la dela tienda es del 2008 y es la que tienen en la tienda.
    ¿en cual de las ds la posición del amortiguador trasero es mejor?
    ¿horizontal o vertical?
  10. er_torero
    12 Oct 2008
    Yo creo que vertical, ya que cuando te subes el peso, directamente hira hacia abajo, y se notara mas que en de horinzntal.
  11. canote
    canote Jose Búho
    16 Feb 2006
    La KTM Score 4.0 es muy bonita, pero está bastante por detrás de la Speed 3.0 en montaje de componentes. Hay que tener en cuenta que esa es la más básica de las Score, y el precio de la Speed era 2399€. Tora contra Reba (no hay color), pedalier Hollowtech contra XT, etc...
    Mi compañero de curro tiene la Speed y va de fábula.
    Ah!, la posición del amortiguador no influye en el comportamiento de una suspensión. Es la suspensión en su conjunto lo que se diseña para que se comporte de tal o cual manera.
    Última edición: 30 Oct 2008
  12. er_torero
    12 Oct 2008
    Tienes razon, pero de verdad que la Score 4.0, sus componentes estan por detras de la speed 3.0?
  13. Tubigo
    Tubigo Iron Baby
    28 Oct 2008
    Santiago D.C.
    Tiene una pintaza acojonante la KTM son preciosas.....
  14. el cid
    el cid Novato
    13 Ene 2008
    entre burgos y zaragoza...
    hola buenas, q paso al final con la bici, te la compraste o no?? en caso afirmativo como va?? es muy racing, es comodo el bloqueo del amortiguador?? a mi me la han ofrecido por 1700€ la verdad es q esta muy bien de precio, es un descuento del 25%,
    gracias por la informacion saludos.
  15. nautilus
    nautilus Miembro
    24 Jul 2008
    yo tengo la score prime,auqneu los componentes no son los mismos si el cuadro y la suspension son iguales ademas de la geometria,mi bici va del carajo sube muy bien y baja tambien,contamina muy poco el pedaleo y es una maquina de rally autentica.....
  16. trekorange
    trekorange Miembro Reconocido
    8 Oct 2006
    poniente granadino
    Hola, alguien que tenga la speed 3.0, a ver si puede despejarme una duda. La talla, mido +-1.65, y no se que talla pillarme si la 38 o la 43.
    No puedo probarla pues donde vivo no hay en la tienda fisicamente, y necesito decidirme por una por otra talla.
    alguien que la tenga puede aconsejarme?
    Gracias.-
  17. canote
    canote Jose Búho
    16 Feb 2006
    La 43 sin duda, la 38 es pequeñísima. ¿No te lo ha dicho el tendero?. La talla 38 es para alguien con una altura de 1'50-1'60 m.
  18. trekorange
    8 Oct 2006
    poniente granadino
    lo he consultado con buhobike, y me recomiendan la 43, pero probando una score en talla 43 me quedaba un poco grande, de ahi la duda, no se que hacer.
    Tambien me surge la duda de si pillar un score o un speed, teniendo en cuenta solo el cuadro, pues el resto de componentes serian los mismos.
  19. canote
    canote Jose Búho
    16 Feb 2006
    Pues si dudas entre esas dos, yo preferiría la Score, aunque tengo una Speed y estoy muy contento. Los cuadros pesan lo mismo, pero el sistema de suspensión de la Score es más sensible, y la trasera más rígida. Eso sí, al llevar más puntos de giro tiene más mantenimiento.
    Soy uno de los mecánicos de Buhobike. Si quieres probarte una Speed en talla 43 llámanos y mi compañero del taller se trae la suya.
  20. trekorange
    8 Oct 2006
    poniente granadino
    gracias canote, no soy de madrid, asi que no podria verla, debeis tener razon en lo de la talla, por algo currais en el tema, la mia sera la 43, pero no estoy decidido del todo, je je
    lo del mantenimiento no me importa, disfruto con la mecanica, trasteando paqui y palla.
    Ahora me tira mas el score rc 2.0 banquita y naranja y no tendria problemas en la talla supongo.
    Bueno si me decido, tendreis noticias mias por ahi.
    un saludo.-
