Nueva act. Base Camp
Discussion in 'GPS' started by javiero_44, Jan 27, 2013.
  1. javiero_44
    javiero_44 Lord de las Cumbres
    Nueva actualiz. 4.1.0.0 .Saludos
  2. elvendrell
    elvendrell Carreteros de Flandes
    El Vendrell (Tarragona)
    Gracias!!
  3. pppcordobes
    Pinoso, Alicante
    Gracias, sabemos ya que mejoras trae??.
  4. elvendrell
    Added support for Garmin Cloud Storage.
    Added support for searching and displaying Custom POIs from devices (GPI file support).
    Added ability to report map errors directly from within BaseCamp.
    Implemented Part I of Find experience rework (simultaneous searches, less confusing input boxes, added Find menu, added support for user data search).
    Added support for new statistics track extension, this should allow BaseCamp and future devices to have the same track statistics.
    Added better error messages for adventure publishing failures.
    Improved behavior when editing or deleting route and track points in a list, BaseCamp now remembers the position in the list.
    Improved decimal precision for low speeds.
    Improved 'Send To Device' and 'Receive From Device' dialogs.
    Fixed an issue where BaseCamp would erroneously prompt for Geotagged photos on Garmin-mode devices.
    Fixed an issue where the folder data list size wasn't preserved.
    Fixed an issue with importing KML files from Google Earth.
    Fixed an issue where the original routes were not restored after cancelling during the calculation phase of a route join.
    Fixed an issue where single digit entry into Arrival/Departure times may not get committed to database.
    Fixed an issue with displaying waypoint comments that take more than 1 row.
    Fixed an issue with missing/corrupt system services. BaseCamp now prompts the user.
    Fixed an issue with sending dog icons to older Garmin devices.
    Fixed an issue with resetting the activity profile.
    Fixed an issue where BaseCamp sometimes would not sync with devices.
    Fixed an issue with restore.
    Fixed some issues with Undo and Redo.
    Fixed shutdown issues.
    Fixed an issue in Danish when viewing route properties.
    Fixed issue where BaseCamp would not display 'TOPO Sweden V3 - Svealand'.
  5. angelov
    Pamplona
    No veo como activar el almacenamiento en la nube. Hay un menú pero luego no sale en el arbol de datos...
  6. santacruzblur
    Following the track
  7. angelov
    Pamplona
    Utilisimo, pero me llega un mes tarde. Ya estoy haciendo lo mismo con el Compe 7 y Dropbox y ya me he acostumbrado a ello, pero bueno es tenerlo y saberlo.
    Me fallaba que no tenía MyGarmin cuenta creada
    Te sigue sin llegar ese Oregon 600, Santa?
  8. santacruzblur
    Following the track
    Hola angelov
    El 600 me llegará bastante más tarde que los Edge, ahora estoy con el Sportiva2, luego los Edge 810 y 510 y después la gama Oregón...falta concretar que modelo si 600 o 650
  9. pppcordobes
    Pinoso, Alicante
    Me tiene loquito ese 650, que buena pinta que tiene. Habrá que verlo puesto en la potencia de la bici.
  10. angelov
    Pamplona
    *****, cómo lo haces... si no llegas pásame alguno y ya los analizo yo gratis y pongo aquí el review
  11. César_75
    César_75 Miembro activo
    Paterna
    Interesante, así puedes descargar tus tracks, que previamente tienes ahí subidos, desde cualquier ordenador, no?
  12. santacruzblur
    Following the track
    Efectivamente :)
  13. santacruzblur
    Following the track
    Llego, llego, no problem :) jajajajaja
  14. pppcordobes
    Pinoso, Alicante
    Al igual que Angelov, yo estaba usando Dropbox para subir todas mis rutas a la nube y tenerlas ahí siempre. Me viene muy bien por si llego a un sitio donde tengo una duda y no tengo esa ruta en el gps. Como en el iPhone tengo el Twonav, simplemente entro en Dropbox y me bajo esa ruta al móvil para poder consultarla. Parece una tontería, pero me ha sacado ya de algún apuro.
    Eso es lo que el nuevo 810 hará, siempre a través del móvil. Como no voy a cambiar de gps solo por eso, seguiré usando este método.
