nuevos, sin estrenar Although all deep groove roller bearings look similar and do a similar job, not all bearings are the same quality or are specific to the application they are used in. You can save money and run cheaper bearings that will wear out more quickly, however in the long run you will simply need to buy more sets of bearings and also have all the time and effort involved in servicing your frame again. The bearings used in this kit are some of the best quality, longest lasting bearings in the world. Brands like SKF, INA/FAG, Enduro. These bearings are designed for performance and durability, add to that the custom weather proofing for outdoors use and you have a bearing kit that is made to handle extreme conditions. These kits contain. 8x KaTec ProRider bearings. 2x bearings to replace those in the upper main frame / linkage pivot point. Superior quality branded bearings. 2x bearings to replace those in the linkage / upper rear triangle pivot point. Superior quality branded bearings. 2x bearings to replace those in the lower rear triangle/main frame pivot point. Enduro brand Extended inner race. 2x bearings to replace those in the seat/chain stay pivot point. Superior quality branded bearings. precio: 30€ +envío
Hola compañero, tengo una trek top fuel 8 del año 2008, los casquillos de fricción que lleva el basculante donde se fija al cuadro han cogido holgura, los desmonté y llevé a una tienda junto con el tornillo pasante para que me los consiguieran originales, al final me los han perdido y no me dan solución, y en la tienda trek de Málaga no me echan cuentas, no se quieren complicar para pedir solo estos casquillos y el tornillo, te cuento todo este rollo por que veo que has puesto un enlace donde aparecen kit de rodamientos para la ex, estos kits son para sustituir todos los casquillos del basculante por rodamientos ??? sabes si los hay para la trek top fuel 8 del 2008 ??? donde los puedo conseguir??? Gracias anticipadas por tu respuesta
