Buenas a todos, ¿Queria saber que os parece esta bici, cuales son sus defectos y sus virtudes? Muchas gracias y saludos. Quedo a la espera de vuestras opiniones CaracterísticasEspecificaciones TécnicasGeometryCuadro aluminio A1 PremiumHorquilla RockShox Dart SL 80mmCambio y mandos Trigger SRAM X-5Frenos Tektro Auriga CompLlantas Alex RHDCubiertas Fast Trak LK Sport CUADROSpecialized A1 Premium Aluminum, fully butted, formed TT, Double ORE DT, externally relieved HT, reinforced disc mount, forged dropouts w/ replaceable hanger, disc only AMORTIGUADORHORQUILLARockShox Dart 3 SL, 80mm, 1 piece magnesium lower, alloy steerer, adj. reb. damping w/ LO and preload adj., size-specific spring rates, disc only DIRECCION1-1/8" threadless, loose ball POTENCIA3D forged alloy, 7 degree rise, 31.8mm clamp MANILLARButted alloy riserbar, 25mm rise, 660mm wide, 8 degree back sweep, 7 degree up sweep PUÑOSSpecialized Enduro, dual compound Kraton, no flange, 131mm FRENO DELANTEROTektro Auriga Comp, hydraulic disc, dual piston w/ 160mm rotor FRENO TRASEROTektro Auriga Comp, hydraulic disc, dual piston w/ 160mm rotor PALANCAS DE FRENOTektro Auriga Comp DESVIADORShimano Deore, 34.9mm clamp, top swing, bottom pull CAMBIOSRAM X-5, mid cage MANDOS DE CAMBIOSRAM X5-R trigger CASETEShimano HG50, 9-speed, 11-34t CADENAKMC X9 w/ reuseable Missing Link PEDALIERShimano FC-M442, Octalink Spline PLATOS44A x 32S x 22S replaceable CAJA PEDALIERShimano BB-ES25, Octalink spline, cartridge bearing, 68mm x 118mm PEDALESAlloy body and cage, 9/16" LLANTASAlex RHD, 26", pinned, alloy double wall w/ eyelet, 32h BUJE DELANTEROForged alloy, hi/low flange, double sealed, ground race, machined disc mount, 32h BUJE TRASEROForged alloy, double sealed, ground race, machined disc mount, cassette, 32h RADIOS2mm (14g) stainless NEUMATICO DELANTEROSpecialized Fast Trak LK Sport, 26x2.0", 60TPI, wire bead NEUMATICO TRASEROSpecialized Fast Trak LK Sport, 26x2.0", 60TPI, wire bead INNER TUBESSchraeder valve SILLINSpecialized XC, Body Geometry, 143mm width, front and rear bumpers TIJA DE SILLINAlloy two bolt, 12.5mm offset, micro adjust, 30.9mm ABRAZADERA SILLINAlloy QR, nylon washer
hola esa bici va muy bien yo estoy esperando un modelo de hardrock del 2010 pero no es ese compre el vas básico porque compre ya las piezas srram porque no me hacen mucha gracia las que trae de serie pero esa es un buen bicicleto.un saludo.
Ahmm yo tenía el más básico del año 2009 pero lo tuve que cambiar porque se me quedaba muy muy corto y me salía mas caro cambiar las cosas que comprarme la pro disc del 2010. Me encantan los cuadros specialized el problema que dicen que de componentes vienen bastante flojitos
por eso yo los cambio porque en vez de unos frenos mecánicos que trae,directamente pongo unos hidráulicos,de unos platos y bielas rs suntour paso a unos shimano slx entiendes por eso lo compro el mas barato si viniese con unos componentes apropiados me compraría la pro o algo así bueno mi hardrock viene la semana que viene si no se equivocan con el pedido otra vez porque me mandaron una epic jajaja.saludos
JEJEJE si tienes toda la razón del mundo para mí el cuadro es de los mejores, poniendo unos componentes competitivos es una grandísima bici. Espero que te llegue bien y no un triciclo o algo así jejeje cosas peores se han visto. Un saludo
hola me parece una bici de lo mas polivalente y seguro que te divertiras con ella tanto para subir como para bajar. Suerte!!!
