Stumpjumper Expert o Fuel EX9
Tema en 'Bicis y componentes' iniciado por niñotoxico, 22 Nov 2009.
  1. niñotoxico
    niñotoxico Toxico Power!
    6 Nov 2008
    Ourense-Vigo
    Hey compañeros estoy pensando en cambiar de bici y ahora he decidido comprarme un makinon....
    mi duda es entre la Stumpjumper Expert FSR:
    CUADRO Stumpjumper FSR M5 manipulated alloy frame, sealed cartridge bearing pivots, replaceable derailleur hanger, 140mm travel
    AMORTIGUADOR Specialized/Fox AFR Brain Shock w/ remote Trail Tune inertia valve, rebound adj. and Brain Fade, 7.875x1.9" Integrated cartridge bearing shock mount.
    HORQUILLA Fox Talas RL, 140/120/100mm travel, alloy steerer, compression and rebound adj. w/ LO
    DIRECCION Campy style cartridge bearings for integrated alloy HT
    POTENCIA3D forged alloy, adjustable rise, 31.8mm clamp
    MANILLARSpecialized XC low rise bar, butted 7050 alloy, 31.8mm, 660mm wide, 8 degree back sweep, 6 degree up
    PUÑOSSpecialized waffle lock on grip (S/M) Specialized Thick lock on grip (L/XL)
    FRENO DELANTEROCustom Avid Elixir CR SL, alloy backed semi-met pads, alloy Elixir CR lever w/ pad contact and reach adj, S/M: 185mm, L/XL: 203mm rotor
    FRENO TRASERO
    Custom Avid Elixir CR SL, alloy backed semi-met pads, alloy Elixir CR lever w/ pad contact and reach adj, S/M: 160mm, L/XL: 185mm rotor
    PALANCAS DE FRENOCustom Avid Elixir CR SL Hydraulic, carbon lever blade, tool-less adj. reach and pad contact
    DESVIADORShimano M660 SLX, DMD, top swing, dual pull
    CAMBIOSRAM X-0, 9-speed, mid cage
    MANDOS DE CAMBIOSRAM X-9 aluminum trigger
    CASETEShimano HG61, 9-speed, 11-34t
    SRAM PC-971, 9-speed w/Power Link
    PEDALIERCustom Shimano FC-M762, 2pc., S: 170mm, others: 175mm
    PLATOS44A x 32A x 22S, 4-bolt, 104/64mm
    CAJA PEDALIERCustom Shimano integrated
    LLANTASCustom DT Swiss X420SL, 24mm w/ eyelets, 28/32h
    BUJE DELANTEROHi Lo disc, CNC flange, sealed cartridge bearing, 9mm DT RWS, alloy QR, 28h
    BUJE TRASEROCustom DT Swiss 330SL w/ alloy freehub, DT RWS QR, 32h
    RADIOSDT Swiss Competition 1.8/1.6mm stainless
    NEUMATICO DELANTEROS-Works Purgatory, 26x2.2", 120 TPI, tubeless ready aramid bead, dual compound
    NEUMATICO TRASEROThe Captain Control, 26x2.0", 60 TPI, tubeless ready aramid bead, dual compound
    INNER TUBESUltralight presta valve
    SILLINSpecialized Format, hollow Cr-Mo rails, SL foam, S/M: 130mm L/XL:143mm
    TIJA DE SILLIN2014 butted alloy, single bolt setback, 30.9mm
    ABRAZADERA SILLIN7050 hard annodized alloy collar w/ QR, 34.9mm clamp ID, black
    o la Trek Fuel EX 9:
    Cuadro Alpha Red Aluminum w/ABP Race, Full Floater, E2 tapered head tube, magnesium EVO Link, oversized pivot bearings, replaceable derailleur hanger, 120mm travel
    Suspensión Delantera Fox 32 F-Series Fit RLC w/air spring, compression, lockout, rebound, alloy E2 tapered steerer, 15QR thru axle, 120mm
    Amortiguador Fox Float RP-23 w/proprietary Trek DRCV, boost valve, Pro Pedal, rebound; 7.25x2.0"
    Ruedas
    Ruedas Bontrager Rhythm Elite Disc wheel system, 6 bolt, tubeless ready
    Cubiertas Bontrager XDX, 26x2.2"
    Transmisión
    Manetas de Cambio SRAM X.9 trigger
    Desviador Shimano Deore XT
    Cambio SRAM X.0
    Bielas Shimano Deore XT 44/32/22
    Cassette SRAM PG970 11-32, 9 speed
    Pedales Crank Brothers Custom Candy C
    Componentes
    Sillín Bontrager Race Lite
    Tija de Sillín Bontrager Race Lite, 31.6mm, 5mm offset
    Manillar Bontrager Race Lite, 40mm rise
    Potencia Bontrager Race Lite, 7 degree
    Dirección FSA NO.57E, E2, ACB sealed bearings
    Juego de Frenos Avid Elixir R, hydraulic disc
    Alguna otra opción?o alguna opinion?
  2. jojiba44
    jojiba44 Miembro
    15 Abr 2009
    Terrassa (BCN)
    Buenass, te decidiste alfinal? Yo estoy en esa situación. A ver si podrías comentarnos alguna experiencia. Gracias!!
