Urgente: Gary fisher, mondraker factor o trek fuel 5.5
Tema en 'Tiendas y Compras. ¿Qué comprar y dónde?' iniciado por ZAR23, 5 Dic 2008.
  1. ZAR23
    ZAR23 Novato
    9 Nov 2008
    HOLA BUENAS, A VER QUIEN ME PUEDE ECHAR UNA MANO...
    CON CUAL SE QUEDAN DE ESTAS 3 BICIS, YA SE QUE CAMBIA EL PRECIO PERO ME GUSTARIA SI MERECE LA PENA HACER UN ESFUERZO O NO.
    DE MOMENTO NO ES PARA DARLE MUCHA CAÑA, PERO CON EL TIEMPO....
    gary fisher hi-fi plus 2008 (1400€)
    Cuadro
    6011 hydroformed butted aluminum mainframe & chainstays, co-molded carbon seatstays, cold-forged dropouts, G2 Geometry
    Horquilla
    RockShox Recon 351 Air, 120mm travel, custom G2 Geometry 46mm offset crown, solo air spring w/Motion Control lockout, external rebound & preload adjustment
    Suspensión
    Custom Tuned Fox Float RP2 w/air pressure, 2-Position Pro Pedal, rebound, 7.5x 2"
    Dirección
    1-1/8" threadless, semi-integrated, semi-cartridge bearings
    Pedales
    Shimano M505
    Desviador
    Shimano Deore M531
    Cambio
    Shimano M772 Shadow XT SGS
    Pulsadores cambio
    Shimano Deore M530
    Cassete
    SRAM PG950 11-32T, 9spd
    Manillar
    Bontrager Race OS Riser, 40mm rise, 650mm width, 7d backsweep, 4d upsweep, 31.8mm Potencia
    Bontrager SSR OS, 10d rise
    Sillín
    Bontrager Race
    Tija de Sillín
    Bontrager SSR, 31.6mm, 400mm
    Ruedas
    Shimano M525 rear hub/Bontrager double cartridge sealed front hub, Bontrager Duster tubeless ready* 28mm wide disc rims, 32h
    Cubiertas
    Bontrager XDX, 2.2 (58/56), 60 TPI, wire bead
    Frenos
    Avid Juicy 3, hydraulic disc, 185mm/160mm rear G2 Clean Sweep 6-bolt rotor
    MONDRAKER FACTOR (1200€)
    Descripción: Cuadro monocoque TTfull butted OBA./Marzocchi MZ Race Lock Out,120mm Fox FloatR rear shox,120,/Formula Oro K18 160mm.Sram X-7+SX5
    Fuel EX 5.5 (1200 €)
    Juego del cuadro
    Tallas 15.5, 17.5, 18.5, 19.5, 21.5"
    Cuadro Alpha Red Aluminum w/Hi/Lo chainstays, oversized bearings, 120mm travel
    Suspensión delantera RockShox Tora 302 Coil w/rebound, TurnKey lockout, alloy steerer, 120mm
    Suspensión trasera Fox Float RP2 w/air pressure, Pro Pedal, rebound; 7.5x2.0"
    Ruedas
    Ruedas Shimano M495 disc hubs; Bontrager Ranger rims w/welded seams and eyelets
    Cubiertas Bontrager Jones XR, 26x2.2/2.25"; 30 tpi
    Transmision
    Manetas de cambio Shimano Deore, 9 speed
    Desviador Shimano Deore
    Cambio Shimano Deore
    Bielas Shimano M442 Octalink 44/32/22
    Cassette SRAM PG950 11-34, 9 speed
    Pedales Alloy platform w/clips and straps
    Componentes
    Sillín Bontrager Race Basic
    Tija de Sillín Bontrager SSR, 20mm offset
    Manillar Bontrager Race, 40mm rise, 650mm width
    Potencia Bontrager SSR, 10 degree, 31.8mm
    Dirección VP-A76C AHS semi-cartridge
    Juego de frenos Shimano M486 hydraulic disc; 180mm rotors (160mm rear rotor on 15.5, 17.5, 18.5")
    MUCHAS GRACIAS DE ANTEMANO
    ACEPTO TODAS LAS SUGERENCIAS Y CONSEJOS
  2. Farnit
    Farnit Baneado
    8 Oct 2006
    Granada
    La GARY FISHER, merecen la pena esos 200€ más, es un maquinón de bici
  3. GRAN CANARIA
    11 Sep 2007
    Mira a ver si te pueden dejar la Fuel EX 6.5 en 1000 € porque yo la consigo a ese precio y es un modelo superior a la Fuel EX 5.5 . Con lo que te ahorras, si quieres más adelante le cambias alguna cosilla y se te queda una bici bastante guapa, además de tener cuadro garantizado de por vida.
    Joé, creo que como no me la pille antes de que se agoten me voy a arrepentir. :(
    Espero haberte ayudado.
  4. RoyBatty02
    RoyBatty02 Miembro
    26 Abr 2008
    A mi también me convence más la Gary Fisher
  5. RaNsEr
    RaNsEr Siempre el ultimo!
    5 Sep 2008
    Benidorm
    Para mi, la Gary Fisher.
  6. Evolution IX
    Evolution IX Baneado
    29 Nov 2008
    Sin duda Modraker NO
  7. Salvis
    Salvis Engancha y pedalea!!
    7 Sep 2007
    Gary Fisher.
  8. k2biker
    k2biker A mi bola
    5 Feb 2005
    Gary Fisher, un pepino de bici y poco vista.
  9. ZAR23
    ZAR23 Novato
    9 Nov 2008
    Muchas gracias por vuestros consejos y opiniones
    la gary fisher tambien me dan garantia de por vida en el cuadro, segun la tienda estaba en 1900 € y la ha bajado, parece que si es cierto, merece mas la pena.
    Muchas gracias de nuevo, y si alguien quiere comentar o aconsejar algo mas... Bienvenido sea... Que quiero empezar a rodar yaaa
    ah por cierto, mido 1´80?? Cual seria la talla correcta??
    Saludos a todos
  10. iglair
    iglair Miembro
    4 Ago 2008
    Yo tengo la Hifi deluxe desde hace 6 meses y la mejora respecto a la fuel ex 6.5 es notoria (de manejar una bici a ir en un tractor....). La geometría es una pasada pero hay que acostumbrarse a ir mucho más comodo y eficiente (no e crees que se pueda subir tan cómodo). Cambiar, solo los frenos, mejor dicho , los discos de los frenos....no me acaban de convencer.
  11. ZAR23
    ZAR23 Novato
    9 Nov 2008
    GRACIAS.:bravo
    RESPECTO A LA TALLA, PARA 1,80...???
  12. Malolux
    Malolux Miembro activo
    7 May 2008
    Granada
    y mondraker por que no? por curiosidad
  13. jokin3
    jokin3 baby ironman
    29 Dic 2005
    Sin duda la 19".
    Yo mido 1.82 uso la Hi Fi Pro en talla 19 y voy perfecto.
    Te va a encantar lo bien que se rueda y lo eficaz que es su suspensión a la hora de subir.
    La geometría Genesis te va a dar una manejabilidad increible.
    Que la disfrutes!!!
