NUEVO vendida specialized Rockhopper-pro
Tema en 'Venta Bicis-Cuadros' iniciado por membrillera, 22 Feb 2018.
  1. membrillera
    membrillera Miembro
    25 Feb 2013
    Cerca del carril bici
    Rockhopper-pro Talla M
    Nueva sin estrenar me ha tocado en un sorteo.
    trae tambien bloqueo de horquilla en el manillar.
    ABRAZADERA Alloy, QR clamp, 34.9mm
    CUADRO A1 SL Aluminum, Sport XC 29 Geometry, tapered head tube, internal cable routing, 135x9mm forged dropouts, chainstay-mounted disc brake, replaceable alloy derailleur hanger
    TIJERA Manitou Markhor 29, rebound adjust, TS air spring, tapered alloy steerer, QR, 80/90/100mm travel (size specific), 51mm offset
    ACCESORIOS
    PEDALES Specialized Dirt
    TRANSMISIÓN
    Platos Stout 2x10, forged alloy
    CASSETTE Sunrace, 10-Speed, 11-36t
    DESVIADOR TRASERO Shimano SLX, Shadow Plus, SGS Cage, 10-speed
    PALANCA DE CAMBIOS Shimano Deore, 2x10
    CHAINRINGS 36/22T
    CADENA KMC X10, 10-speed w/ Missing Link™
    DESVIADOR DELANTERO Shimano Deore FD-M618, 34.9mm clamp, down-swing
    EJE DE CENTRO Threaded external, 73mm BB
    DIRECCIÓN
    PUÑOS Specialized Sip Grip, half-waffle, XS/S: regular thickness, M/XL: XL thickness
    MANUBRIO Stout Pro double-butted alloy, 10mm rise, 8-degree backsweep, 6-degree upsweep, 720mm width, 31.8mm
    ASIENTO Henge Sport, steel rails, 143mm
    Tija Alloy, 12mm offset, 2-bolt clamp, 30.9mm
    POSTE Stout 3D-forged alloy, 31.8mm, 6-degree rise
    FRENO DELANTERO Shimano BR-M365, hydraulic disc, resin pads, 180/160mm rotor
    FRENO TRASERO Shimano BR-M365, hydraulic disc, resin pads, 160mm rotor
    RUEDAS Stout XC SL 25 29, alloy, disc only, double-wall, 25mm internal width, 24/28h, tubeless ready
    MAZA DELANTERA Shimano Center Lock, disc, 100x9mm QR, 24h
    CUBIERTA TRASERA Ground Control Sport, Flak Jacket flat protection, wire bead, 29x2.1"
    MAZA TRASERA Shimano Center Lock, disc, 135x9mm QR, 28h
    CAMARAS Presta, 40mm valve
    RAYOS Stainless, 14g
    LLANTA DELANTERA Ground Control Sport, Flak Jacket flat protection, wire bead, 29x2.3"
    https://www.specialized.com/hn/es/rockhopper-pro-de-hombre/p/128989?color=240211-128989
  2. membrillera
    membrillera Miembro
    25 Feb 2013
    VENDIDA
