Hola. Podes darme vuestra opinion sobre estas dos bicis Bh xt-lx precio 1500 (ahora en el corte ingles 1124 con el 25% de dto) O DECATHOLN 9.2 (Sale por 1499) BH Cuadro: fs aluminio 7005 asymetric (100mm-120mm) Amortiguación: Rock Shock Bar Horquilla: Rock Shock Pilot SL Dirección: A-head 1''1/8 Frenos: Formula B4 Pro 160mm Maneta de Freno: Formula B4 Pro Mandos: Shimano Deore Pedales: Automáticos Bielas: fsa mega exo Cubiertas: BTT 26 x 2,00 x-country Llantas: Mavic XM317 disc Bujes: Shimano fhm475 Potencia: fsa aluminium A-Head Manillar: fsa XC180 Desviador: Shimano LX Cambio: Shimano XT 9v Sillín: Bassano Niagara Tija Sillín: Aluminio 27,2x350 Colores: Plata-Rojo, Plata-Negro Tallas: 40-45-50 Peso: 13.9 kg. decatholn ame - N.E.U.F. long travel suspension system - 120mm of travel - 2750g in size L (with shock absorber) - DBXL and Alu 6061 N.E.U.F.: minimum pumping and maximum performance. 120mm suspension: access all areas, at any speed. Suspension - Fork: Manitou Black Super Air SPV 120mm - Shock absorber: Manitou Radian R 190mm*50mm The key in a fully suspended bike is the balance of the suspension. The SPV system means anti-pumping at the front and rear for perfect balance. Drivetrain - Crankset: Truvativ Firex Team 22x32x44 - Front derailleur: Shimano LX - Rear derailleur: Shimano XT - Shifters: LX Dual Control - Cassette: Shimano LX 11x32 9 speeds - B/B Truvativ ISIS Giga Pipe 3 bearings. The ISIS crankset case increases rigidity. Each pedal turn is instantly transmitted to the rear wheel. The new LX Dual Control shifters are comfortable and accurate Riding position - Handlebar: Rockrider Comp Rise 640mm Oversized - Stem: Rockrider oversize 7° - Saddle post: Rockrider Comp 29.8 - Saddle: Fizik Nisene - Clipless pedals: Shimano M520 - Steering set: FSA Intellaset Pro An all-round bike needs wider, higher and stiffer steering, with an oversize handlebar. This means more control and comfort at high speeds. Fizik saddle; narrow and comfortable, it looks good too. Wheels - Rims: Mavic XM317 - Hubs: Formula DC91/DC32 - Tyres: Hutchinson Bulldog 2.1 Airlight. High quality wheels, annular bearing hubs and wide tyres for more grip and performance. Brake set - Shimano LX hydraulic disc brakes Simplicity and performance. No adjustments needed for powerful and progressive braking in all conditions. Weight 12,9 kg in size L.
jmsusvi, pregunta en Ciclohobby por cuanto te sale la BH, te vas a descojonar sobre el precio del Corte... Saludos CordialeS!
pos va se que no. He llamado a ciclohobby y sale por 1150 por 1124 del corte ingles. vale que se el servicio que ofrecen (en gijon) es muy deficiente pero mejor que no tenerle.
