El post del Garmin Fenix 3
  1. Gibri
    Gibri Miembro Reconocido
    2 Sep 2011
    Punta Umbria
    Ayer seur se llevó el mio por muerte súbita.... Veremos que pasa y cuanto tiempo tarda...
  2. rdm01
    rdm01 Miembro activo
    9 Sep 2015
    Bratislava
    Qué tiempo tenía de comprado?
  3. Gibri
    2 Sep 2011
    Punta Umbria
    Comprado en Julio
  4. rdm01
    9 Sep 2015
    Bratislava
    Pues lástima. Espero que el próximo no te salga rana :-(
  5. statofix
    statofix Miembro
    18 Abr 2010
    Saludos a todos. He visto que hay un nuevo Widget " perf cond " pero a mí no me funciona ¿ alguien sabe que es y cómo funciona ?
  6. TheBagInTheHead
    TheBagInTheHead Miembro activo
    8 Oct 2013
    De la página del forerunner 630:
    http://www8.garmin.com/manuals/webh...UID-71F0FE27-D086-420F-BDE0-D7A456D6515D.html
    Viewing Your Performance Condition
    Before you can view your performance condition, you must put on a heart rate monitor and pair it with your device
    As you run, the performance condition feature analyzes your pace, heart rate, and heart rate variability to make a real-time assessment of your ability to perform compared to your average fitness level. During the first 6 to 20 minutes of your run, the watch displays your performance condition score. For example, a score of +5 means that you are rested, fresh, and capable of a good run. You can add performance condition as a data field to one of your training screens to monitor your ability throughout the run. Performance condition can also be an indicator of fatigue level, especially at the end of a long training run.
    NOTE: The device requires a few runs with a heart rate monitor to get an accurate VO2 max. estimate and learn about your running ability .
    Add Performance Condition to a data screen .
    Go for a run.
    After 6 to 20 minutes, your performance condition appears.
    Scroll to the data screen to view your performance condition throughout the run.
  7. statofix
    statofix Miembro
    18 Abr 2010
    Gracias por la información, pero yo lo he usado con la banda cardiaca haciendo bici y no me marca nada, lo tengo puesto como campo de datos y tampoco marca nada.
  8. TheBagInTheHead
    8 Oct 2013
    Para la bici necesitas un medidor de potencia, si no calcula el VO2 max (y necesitas el potenciometro para que te lo calcule), no hay "performance condition".
    Corriendo sale más barato...
  9. statofix
    statofix Miembro
    18 Abr 2010
    ok . Gracias .. Queda claro
  10. juanitovi
    juanitovi Miembro activo
    12 Feb 2016
    Benicasim
    Buenas
    Llevo un par de dís con el Fenix, pero no soy capaz de vincular el reloj al iphone 6s
    Hago todo como indica, inicio BT en Garmin, abro app en Iphone y doy a vincular pero nada...
    Alguien puede iluminarme?Gracias
  11. rdm01
    9 Sep 2015
    Bratislava
    Me permito añadir una explicación un poco "más en cristiano" de cómo funciona este tema en carrera a pie ;-)
  12. Speed Rallon
    Speed Rallon Miembro
    21 Sep 2012
    Barcelona (Olivella)
    A todos os sale el "Performance Condition" como un nuevo Widget?
  13. Jmerino
    Jmerino Miembro activo
    2 Ago 2015
    Es un campo de datos que esta en el apartado otros.
  14. Speed Rallon
    21 Sep 2012
    Pensaba que se referían a un widget tipo altitud,barómetro,tiempo etc.
  15. Gibri
    2 Sep 2011
    Punta Umbria
    Una pregunta para los que alguna vez han mandado el reloj al Sat:
    Cuando se lo llevan, te llaman, te escriben o algo para decirte si te lo arreglan o te lo cambian??
  16. inarut
    inarut Miembro Reconocido
    7 Jun 2011
    Alcalá de Henares
    Cual es la mejor manera de cargar tracks en el fénix 3? Llevo 2 días con él y no se si se cargan directamente desde wikiloc o hay que hacerlo a través de Garmin Connet, Basecamps, etc.
  17. abade_abad
    abade_abad Miembro Reconocido
    27 Ago 2008
    Mérida
    una o dos páginas atrás se hablaba del tema
  18. inarut
    7 Jun 2011
    Alcalá de Henares
    Es que me acaba de pasar esto que comentáis, he cargado una ruta directamente del wiki y al desconectar el reloj del pc se me ha quedado pillado un buen rato, y como es nuevo me he jiñado por las patas abajo, ha vuelto en si al apagarlo y encenderlo un millón de veces, habrá que intentar hacerlo con el bluetooth como dice el compañero de arriba.
  19. rdm01
    9 Sep 2015
    Bratislava
    Si te han dicho que lo envíes al sat te enviarán otro reloj en unos días (entre 7 y 10 días). No te avisan en ningún momento de nada.
  20. abade_abad
    27 Ago 2008
    Mérida
    hasta ahora solo he usado el método del directorio NewFiles
