  1. RedMars
    RedMars Miembro Reconocido
    16 Abr 2007
    Zevilla
    ¿Pesos?
  2. termaltake
    termaltake Doctor House
    22 Ene 2012
    La Isla Bonita
    Estan al salir en las tiendas de siempre :)
    Disc Rotors Tech Specs >
    Standard rotors:
    • Standard rotors are laser cut from a sheet of custom steel for fantastic durability
    • New design with wider braking surface to make them more compatible with other companies brakes
    • If you have an old/odd rotor you are looking to replace there's a good chance we could have something to suit
    • Available in:140, 160, 180, 183, 185, 200, 203 and 205mm
    • Different bolt fixings available to fit a wide range of hub designs
    • Weight 180mm: 142g
    Floating rotors:
    • Popular amongst both performance orientated riders and those just looking for something a little different
    • Custom steel braking surface riveted to an aluminium central carrier
    • Available in: 140, 160, 180, 183, 200, 203 and 205mm
    • Floating design deals with changes in temperature
    • Available in our six colour options
    • Weight 180mm: 146g
    Vented rotors:
    • The vented rotor is designed specifically for our Tech V series brakes
    • The rotor uses internal fins to allow the air to flow between the two friction parts
    • The induced air flow significantly reduces heat build up in the rotor
    • Fantastic and consistent braking performance in wet conditions thanks to its capability to clear the water layer through its fins
    • Dyno tests show up to 15% less heat build up compared to our floating rotors
    • Weight 203mm: 288g
    180,183 or 185 ?:
    Over the years there has been some confusion over this "middle" sized disc. Although we will continue to manufacture 183mm discs and their corresponding H and J mounts, we have decided to standardise on the more common 180mm disc size. This requires the use of two new mounts: L- Standard post mount to post mount (180mm) and N-IS rear to post mount (180mm)
  3. moriscos
    moriscos Miembro Reconocido
    15 Ago 2012
    Puff, ni idea
    Ahí estaré yo con la caña preparada
  4. moriscos
    15 Ago 2012
    Puff, ni idea
    Estos de Winstanleys para quitarse el sombrero.
    Y decía en que les entraría en stock para el día 10, y hoy día 11 ya están aquí.
    Muchos deberían/mos aprender de los ingleses y alemanes. Estamos muy lejos aún
    • Me Gusta Me Gusta x 9
    • Útil Útil x 2
  5. gargon
    gargon Miembro activo
    11 Ene 2013
    Oye tío, en ¿euros cuanto te ha costado? que me queda pillar el de delante! puesto en casa digo, con envío y tal
  6. moriscos
    15 Ago 2012
    Puff, ni idea
    Según modelo, mira en donde he dicho y busca tu modelo. Los portes son gratis porqué pasarás del mínimo. El mejor cambio te lo aplican pagando con tarjeta de crédito. Y para pasar ee libras a euros múltiplica por 1'3 y sale muy apx.
  7. Talvin
    Talvin Espondilitico Rodante
    13 Feb 2006
    Intentando no pisar dos veces el mismo sendero
    me ha llegado esta tarde las pastillas de uberbike las blancas (race) frente a las galfer rojas (advanced), la chapa metalica es mas ancha (quizas un mm) y se nota algo mas pesada en la mano.
    ya veremos como funciona en los senderos.
  8. serjforius
    serjforius Adicto Pinion
    6 Sep 2009
    Córdoba
    vaya pasada de frenos, esos quiero verlos pronto en persona, no tardes en montarlos jejej
  9. victir
    victir Pakete Member
    15 Jun 2008
    Coslada
    Si no tienen el que buscas puedes mirar en merlincycles.com que tampoco suelen salir mal de precio. Al meterlos en la cesta te hacen un 10% de descuento y con el envio incluido.
  10. gargon
    11 Ene 2013
    El mismo modelo que el tuyo 127,99 libras
    Ya he mirado son bastante mas carillos la verdad jejeje,
    166€ con cable trenzado no esta mal no? el tech 3 e4 en winstaleys
  11. moriscos
    15 Ago 2012
    Puff, ni idea
    145 me ha salido a mí, 111 £, con latiguillo trenzado.
    Portes gratuitos
  12. gargon
    11 Ene 2013
    Acabo de ver que está con mas descuento el tuyo de color rojo jeje, por 13 eurillos mas si que merece la pena el latiguillo trenzado no ?
  13. victir
    15 Jun 2008
    Coslada
    No llega a 2€ de diferencia:confused: 168€
  14. gargon
    11 Ene 2013
    No lo habia mirado en cesta :(
    Pero solo tienen en negro, yo lo busco morado
  15. victir
    15 Jun 2008
    Coslada
    No es morado es lila:oops::D:D
  16. termaltake
    22 Ene 2012
    La Isla Bonita
    El purple :p en wiggle o chain ;)
  17. victir
    15 Jun 2008
    Coslada
    Me lo pense mucho en pillarlos morados para la cabra verde, al final a lo clasico y los puse negros que pegan con todo:D
  18. justopuebla
    justopuebla Miembro Reconocido
    15 May 2015
    Pobra do Caramiñal
    Y sinó le haces tú el tuning fashion! ;)
    [​IMG] [​IMG]
  19. victir
    15 Jun 2008
    Coslada
    Unos toquecitos verdes no quedarian mal....:D:D
  20. gargon
    11 Ene 2013
    Como os gustan las chuches eeeee gorfos !!!! jajajaja
    Me lo cogeré en winstaleys dentro de poco, que lo tienen LILA y para mi bici le va bien.
