Garmin Edge 1030?
  1. yiyoe
    yiyoe Miembro Reconocido
    8 Ene 2006
    Entonces ya cambia la película....
    El móvil normalmente lo llevamos en la mochila.
  2. Luis D.C
    Luis D.C Miembro Reconocido
    28 Sep 2010
    Granada
    Ya lo tengo aquí , y en pantalla principal en ruta y mapa ya aparece tb ....no tardaré mucho en mandarlo , este es de abril , hay que sacarle maximo partido a los 2 años de garantía
  3. jxupi
    jxupi Miembro activo
    3 Sep 2009
    La Noguera
    Respecto lo del ingles a mi tambien me pasaba. Creo que lo arregle a través de la app de garmin connect y las preferencias de usuario o del dispositivo
  4. tyrun
    tyrun Miembro Reconocido
    18 Oct 2015
    Beta 5.33 https://www8.garmin.com/support/download_details.jsp?id=12819
    Changes made from version 5.28 to 5.33:
    Fixed a potential freeze when powering off.
    Fixed CIQ custom fonts.
    Fixed several CIQ Menu2 issues.
    Fixed an issue that could prevent a radar low battery message from displaying.
    Changes made from version 5.27 to 5.28:
    Fixed an issue causing freezes when powering down introduced in 5.27.
    Prevented crashes caused by adding new segment files during an activity.
    Fixed issues with elevation units on the Varia Vision.
    Added the ability to add CIQ data fields to the map data screen.
    Fixed issue where auto backlight could activate despite the setting being turned off.
    Fixed a light settings vulnerability that could cause the light settings to not be saved.
    Changes made from version 5.00 to 5.27:
    New Feature: Added Connect IQ 3.0 support.
    New Feature: Added Shimano STEPS sensor support.
    New Beta Feature: Added extended display mode support. Select Menu > Extended Display Mode to allow the Edge device to act as an extended view of a supported Garmin multisport watch's data fields during a multi-stage activity such as a triathlon. Follow the on-screen Edge and multisport instructions to get started.
    Improved sensor searching flow.
    Fixed issue causing unexpected u-turn sharp bend warnings.
    Fixed issues preventing device-to-device transfers from completing and made improvements to the connection flow.
    Fixed various issues with the Varia Vision.
    Fixed issue with Physio TrueUp duplicate activity detection.
    Fixed issue where VO2 max could be corrupted.
    Fixed issue that could cause the device to crash while connected to the phone.
    Fixed bike light beam angle and light mode data field text.
    Fixed the Follow a Course flow for indoor trainer mode.
    Fixed issue with the device where going into mass storage from a power off state may cause Garmin Express to offer a map update that the device does not need.
    Improved Physio TrueUp responsiveness by syncing with the phone after powering up or resuming from suspend.
    Última edición: 23 Ago 2018
  5. ttalonso
    ttalonso Miembro Reconocido
    5 Nov 2009
    el link no es correcto. Yo desde el lunes llevo la 5.35. He salido 2 veces creo y no he notado nada a mejor ni a peor... el mando remoto ya ni lo pruebo, lo quité de la bici porque me ponía de los nervios.
  6. Ortziomenaka
    Ortziomenaka Miembro Reconocido
    2 Abr 2015
    Andoain
    Pero hay alguna versión final nueva o la última oficial es la 5.0?
    Enviado desde mi iPhone de carbono
  7. tyrun
    18 Oct 2015
    Corregido El enlace pero 5.35 no la veo por ningún lado
    No.
  8. samuel_ib
    samuel_ib Miembro
    14 Ene 2017
    Almería
    Me ha pasado hoy una cosa muy extraña...se me ha apagado el GPS dos veces y al encenderlo la segunda vez.. sorpresa..el dichoso halo azulpero lo raro es que cuando estaba acabando la ruta ha desaparecido y en casa trasteandolo tampoco lo tenia.. a vosotros os ha pasado que al principio desaparece y con el tiempo se hace permanente? Debería tirar de garantía ya??
  9. Luis D.C
    28 Sep 2010
    Granada
    A mi me ha coincidido la aparición del halo con el primer apagado misterioso o_O
  10. Jam23
    Jam23 Miembro activo
    4 Sep 2009
    Urdaibai
  11. churrasco
    churrasco Miembro Reconocido
    17 Dic 2008
    llanes asturias
    PM
    La versión de firmware 6.00 para el Edge 1030 ya está disponible. Esta actualización se puede descargar a través de Garmin Express o Garmin Connect Mobile cuando esté disponible.
    8/23 Lanzamiento incremental 20%
    Cambios realizados de la versión 5.00 a la 6.00
    Nueva característica: Se agregó compatibilidad con Connect IQ 3.0.
    Nueva característica: Se agregó el soporte del sensor Shosano STEPS.
    Nueva función Beta: Se agregó compatibilidad con el modo de pantalla extendida. Seleccione Menú> Modo de visualización extendida para permitir que el dispositivo Edge actúe como una vista ampliada de los campos de datos de un reloj multipropósito Garmin admitidos durante una actividad de varias etapas, como un triatlón. Siga las instrucciones en pantalla de borde y multideporte para comenzar.
    Se agregó la capacidad de agregar campos de datos CIQ a la pantalla de datos del mapa.
    Flujo de búsqueda de sensores mejorado.
    Se corrigió el problema que causaba advertencias inesperadas de giro brusco en sentido contrario.
    Se corrigieron los problemas que impedían que las transferencias de dispositivo a dispositivo finalizaran y se realizaron mejoras en el flujo de conexión.
    Se corrigieron varios problemas con Varia Vision.
    Se solucionó el problema con la detección de actividad duplicada de Physio TrueUp.
    Se solucionó el problema donde el VO2 max podría estar dañado.
    Se corrigió el problema que podía causar el bloqueo del dispositivo mientras estaba conectado al teléfono.
    Se corrigió el ángulo del haz de luz de la bicicleta y el texto del campo de datos del modo de luz.
    Se corrigió el flujo Seguir un curso para el modo entrenador interior.
    Se solucionó el problema con el dispositivo en el que el almacenamiento masivo desde un estado de apagado puede hacer que Garmin Express ofrezca una actualización del mapa que el dispositivo no necesita.
    Se corrigió el problema por el que la retroiluminación automática podía activarse a pesar de que se desactivaba la configuración.
    Se corrigió una vulnerabilidad de configuración de luz que podría causar que la configuración de luz no se guarde.
    Se corrigió un posible congelamiento al apagarlo.
    Se corrigió un problema que podía evitar la visualización de un mensaje de batería baja de radar.
    Fallos evitados causados al agregar nuevos archivos de segmento durante una actividad.
  12. ttalonso
    5 Nov 2009
    perdón 5.33 quería poner y no .35
    Por lo que veo la versión 6, es básicamente la versión beta que la publican para el resto, dando por "estables" esos cambios.
  13. thunderlex
    thunderlex Miembro Reconocido
    30 Ago 2009
    Buenas tardes. 2 días con el 1030 y ya empiezo a tener problemas.
    Versión 5.0 y cuando intento actualizar me dice que no hay nada más nuevo disponible.
    Salgo de ruta, el tiempo en movimiento me lo mide bien, pero la distancia mal. Sube la ruta a Connect con el tiempo bien y todo, pero la velocidad no cuadra.
    Comparándolo con la que vincula a Strava, éste detecta que el tiempo en movimiento ha sido menor (cómo si la velocidad en algunos momentos hubiera ido a 0).
    Lo curioso es que yo voy mirando la velocidad en todo momento y nunca marca 0km/h.
    ¿A alguien más le ha pasado esto?
    Gracias de antemano
  14. churrasco
    17 Dic 2008
    llanes asturias
    La actualización no siempre está disponible para todos a la vez
    Llevas autopause en el garmin ?
  15. thunderlex
    30 Ago 2009
    Sí claro, si el tiempo lo mide bien, cuando paro se para y cuando ruedo va contando...
  16. churrasco
    17 Dic 2008
    llanes asturias
    Es que el autopause puede causar algún problema
    A veces para aunque te estes moviendo , puedes tener puesta una velocidad a partir de la cual por debajo se para
    Yo no lo llevo activado nunca
  17. thunderlex
    30 Ago 2009
    Yo lo tengo puesto en "cuando me detenga". Lo he llevado así en todos mis Garmin y siempre 0 problemas :-(
  18. thunderlex
    30 Ago 2009
    Precisamente me ha saltado la 6.0 esta noche. Mañana miraré a ver si esto ha resuelto el problema...
    Os voy contando..
  19. danicajilla87
    danicajilla87 Miembro activo
    25 Oct 2015
    Niebla (Huelva)
    Si te ha salido lo tienes siempre, solo depende del ángulo desde el que lo miras y de la luz exterior.
    Yo en la bici de carretera con soporte adelantado lo veo siempre, a veces mas fuerte y otras menos (depende de la luz del día), sin embargo en la MTB con soporte en la potencia, a veces no lo veo y otras lo aprecio un poco. Tambien he comprobado que con las gafas polarizadas aun se ve mas el halo.
    Enviado desde mi Mi MIX 2 mediante Tapatalk
  20. danicajilla87
    25 Oct 2015
    Niebla (Huelva)
    A mi me ha saltado la v6 esta tarde pero no he actualizado, con la 5 me va como nunca, creo que esperaré.
