Garmin Edge 1030?
  1. carlosdotor
    carlosdotor Miembro
    29 Sep 2013
    valencia
    A mi tambien me pasa. Que versión de Basecamp instalamos?
  2. Dani Colome
    Dani Colome Miembro
    12 Mar 2014
  3. carlosdotor
    carlosdotor Miembro
    29 Sep 2013
    valencia
  4. siconino
    siconino Miembro activo
    24 Feb 2008
    ¿Realmente merece la pena instalar topohispania? ¿Que ventajas tiene sobre los que trae garmin?
  5. Trisk3l
    Trisk3l Outra vaca no millo
    6 Ago 2008
    Donde la lluvia es arte
    Nueva versión de firmware:
    Changes made from version 6.30 to 7.00:
    • New Beta Feature: Galileo satellites. There is now support to use the Galileo network of satellites to assist in getting GPS fixes. With the correct GPS firmware, this option can be enabled by selecting GPS+Galileo in the GPS setting. Sync the device with Garmin Express to make sure that the new line of GPS firmware is provided to the device. Without this, the option will not be available.
    • Added cycling dynamics support for 3rd party power sensors.
    • Updated smart notification categories. In the phone settings, social and other smart notification categories can be enabled. This will make the Edge show notifications from other applications depending on how they are categorized by Garmin Connect Mobile. Apps like WhatsApp, GroupMe, and Twitter may show up under social and things like e-mail, calendar, and news may show up under other. These categories are off by default and must be enabled to be seen.
    • Fixed an issue causing cadence and power data dropouts.
    • Fixed the activity profile routing mode getting reset to Road Cycling mode.
    • Added prompt to indicate when a course has more course points than are supported by the device.
    • Improved Shimano STEPS response time.
    • Fixed lens mode VIRB setting.
    • Fixed issue with transmitting front and rear gear information to the Varia Vision.
    • Fixed sharp bend notifications on the Varia Vision.
    • Fixed crash when using Varia Vision with workouts.
    • Fixed issue with elevation back correction that could allow large dips in elevation.
    • Fixed issue where the GPS data field did not match the GPS indicated by the status bar.
    • Fixed issue where virtual partner features were disabled for third party GPX TRK courses.
    • Added the current software version to the power on page.
    • Fixed issues with device transfers.
    • Completing a segment will now turn on the backlight.
    • Added a minimum scale to the altimeter page so that small elevation ranges are reflected properly.
    • Fixed elevation zooming issue with large courses/activities/segments (>100mi or km).
    • Improved activity auto-start when the device is stationary.
    • Updated radar tone to be easier to hear.
    • Minor bug fixes and stability improvements.
    • Minor CIQ improvements.
    Respecto a la actualización del firmware GPS el proceso que he realizado:
    - Me ha saltado la actualización al encender el 1030 (conectado a WiFi), he hecho la actualización.
    - He conectado el 1030 al PC y he sincronizado con Garmin Express.
    - Después de desconectar del PC y reiniciarse el 1030 ya aparece la opción de GPS + Galileo.
  6. churrasco
    churrasco Miembro Reconocido
    17 Dic 2008
    llanes asturias
    Topohispania puede darte algún problema de cuelgues . Y de medirte de menos los kms totales de la ruta
  7. siconino
    24 Feb 2008
    Ok gracias por la info. De momento me quedaré con los que vienen.
    Salu2!
  8. josjaker
    josjaker Miembro
    19 Jul 2007
    Justo era eso. Las capturas de pantalla que colgué el otro día con la calibración OK pero con valor 0 es porque estaba sincronizado por BT. Lo he borrado y conectado como ant+ y ya me aparecen los valores normales. Gracias!
  9. Otxan19
    Otxan19 Miembro
    20 Ene 2016
    Hola,
    tenia el problema de que no me contaba los km por instalar topohispania(instalado en el garmin,no en tarjeta memoria).Elimine los archivos que puedan causar el defecto, pero sigo con el mismo problema.Por lo que quiero eliminar el topohispania totalmente.
    Como lo desinstalo manteniendo todo lo que tenia en el garmin 1030?
    Tampoco me importaria mucho dejarlo como el primer dia.Esto se hace restaurandolo no?
    Grcias
  10. Muchmuch
    Muchmuch Camestrencades
    20 Sep 2007
    A l'hombra del Farell
    Hard Reset:
    Con el gps apagado presiona los dos botones de abajo, Play y Lap, i sin soltarlos aprietael de encendido y mantenlos apretados hasta que la pantalla se ponga blanca, luego sueltas y listo.
  11. sainzajump
    sainzajump Miembro Reconocido
    26 Mar 2006
    En bici . . .
    Qué diferencia hay entre el glonass y ek galileo? Gracias
  12. Dani Colome
    Dani Colome Miembro
    12 Mar 2014
  13. sainzajump
    26 Mar 2006
    En bici . . .
  14. yaijo
    yaijo Miembro
    16 May 2009
    lo acabo de actualizar y no me aparece la opcion galileo por ningun lado,
  15. Deivicinho
    Deivicinho Miembro activo
    10 Mar 2015
    A mi tampoco me aparecía al actualizar. Lo conecté al connect del pc y después ya apareció.
  16. yaijo
    yaijo Miembro
    16 May 2009
    ok
    ya esta
  17. JaN-SoLo
    JaN-SoLo Miembro Reconocido
    26 Dic 2014
    Asturias
    Según tengo entendido, no es que use el GPS, el Glonass o el galileo, usa el GPS siempre y se apoya en los otros dos. Yo uso GPS a secas y por carretera sin problema. Otra cosa es que en montaña te metas en un bosque y entonces necesites que tire de una de las otras redes para mayor precisión porque pierdas cobertura del GPS.
  18. ttalonso
    ttalonso Miembro Reconocido
    5 Nov 2009
    glonass y galileo consumen más batería, y yo no tengo problemas de precisión
  19. Pacma
    Pacma Miembro Reconocido
    11 Dic 2013
    Yo uso gps+glonas y nunca me fue mal, hoy use gps+galileo y tampoco me fue mal... He dejado en galileo... Ya me fijare mas...
  20. craco20
    craco20 Miembro Reconocido
    26 Feb 2011
    hola foreros, una pregunta, alguien tiene problema al conectarlo a un iphone??? a mi cada dos o tres dias, me cuesta, borrarlo del iphone y volver a emparejarlo................alguien mas tiene el problema?
  1. Este sitio utiliza cookies para ayudar a personalizar el contenido, adaptar tu experiencia y mantenerte conectado si te has registrado.
    Para continuar utilizando este sitio, debe aceptarse nuestro uso de cookies.
