Garmin edge 500
  1. relayer
    relayer Ex HIGH JUMPER
    28 Oct 2006
    Zona Legazpi, Madrid
    También encontré esto por si acaso:
  2. relayer
    28 Oct 2006
    Más información:
    En esta web: https://forums.garmin.com/showthrea...rmware-upgrade-from-2-8-to-3-0-Is-it-worth-it dicen que la actualización del 2.8 al 3.0 hace que las gráficas de alturas vayan de 2 en 2 m cuando antes iban de uno en uno. que las gráficas de alturas empeoran mucho. Que si no usas medidor de potencia, que mejor te la ahorres. Creo que me ahorraré la 3.2 también. No entiendo eso de que ahora soporto manufactura.
    Aquí tenéis todos los firmwares: https://forums.garmin.com/showthread.php?18937-Looking-for-2-6&p=89239#post89239
    Instrucciones: I didn't get version 2.70, no loss, given the mess it caused.
    Version 2.40 is the last version where courses "work", at least the map doesn't disappear. But it has other issues...
    Once you download the file to someplace on your PC:
    1. Plug the 500 into the PC.
    2. Once the 500 is ready, copy the file to the Garmin subdirectory on your unit, renaming it to gupdate.gcd. The 500 will appear as another drive in explorer, for me, it's drive E:
    3. Save your Settings\Settings.fit, Elevations\Elevations.fit, and possibly the Sports\Cycling.fit files so that you don't need to reenter all that data after the firmware update. (copy them back to the PC). These files are located in the various sub-directories under the Garmin folder. Note, updating the firmware doesn't usually mess with these files (a 'full reset' normally proscribed by Garmin support does).
    4. Safely remove the 500 from the PC.
    5. Power up the 500. If you are loading an older level firmware, it will ask you to verify you want to do this.
    6. Let it update. This may take a while, be patient. Be very patient. Very.
    7. Once the update completes, power the 500 back down.
    8. Reattach to the PC and restore the files saved in step 3.
    9. Safely remove the 500 from the PC.
    10. Power up the 500, rescan for HRM, GSC-10, other devices, and re-pair them.
    Y si os cargáis el cacharro, hay manera de recuperarlo:
    Also, here's a zip file necessary for restoring the filesystem on the Edge 500. Zip: https://docs.google.com/open?id=0B3tOe3oU8dOEaWZfN29SQVF0MHM
    MAKE SURE YOU READ Alan's POST BEFORE PROCEEDING!!!!https://forums.garmin.com/showthread.php?27893-3-0-Update-Issue&p=135259#post135259 There is no need to perform the actions described unless the device is completely bricked and you have no other alternative.
    Ya no sé si actualizarlo. No entiendo que sean tan frágiles estos cacharros para actualizarlos.
  3. ayala5
    ayala5 Miembro Reconocido
    25 Sep 2009
    Aquí
    Mi Garmin se ha vuelto loco. Ayer y hoy haciendo rodillo me marcaba velocidades en torno a los 60-70km/h, ayer por ejemplo, en una sesión de hora y media salió una media de sesenta y algo por hora, por lo que hice 90km!!!! También se paraba y al instante iniciaba la marcha.
    Ajusté de nuevo el sensor de la rueda trasera para ver si era de eso, pero estaba en principio todo correcto. No sé de qué puede ser.
    Puede deberse a que nunca he actualizado el software???
    Alguien me puede ayudar, please???????????
  4. zsrash
    zsrash Miembro activo
    4 Sep 2008
    Has comprobado la pila?, a un amigo mío también le pasaba algo parecido y creo que lo solucionó así
  5. zsrash
    4 Sep 2008
    Perdona, la pila del sensor, claro, aunque lo regules y las lucecitas fucionen, si la pila empieza a bajar, el sensor falla. A ver si es eso.
  6. J0s3m4_7
    J0s3m4_7 Miembro activo
    17 Jul 2011
    San Fernando
    Con que nombre sale ¿yo lo hago y al conectar de nuevo al pc ya no esta en la carpeta new files, se habrá movido a no sé dónde jaj
  7. pablorider
    pablorider Miembro Reconocido
    22 Ago 2012
    Toledo
    Hace tiempo ya pregunte pero vuelvo con dudas. Estoy dudoso entre este y el dakota 20, tenia claro el dakota porque yo lo usare mas para seguir rutas, pero ahora me dicen que con el500 aunque no tenga mapas se sigue muy bien... Hasta con la mtb que es lo que yo hago. Es esto cierto? Lo usais para seguirlas y no os perdeis?
  8. ayala5
    25 Sep 2009
    Aquí
    Gracias por la recomendación. Ya la he comprado y mañana la pondré, a ver si así se soluciona ;)
    Gracias!
  9. OFFNI
    OFFNI Miembro Reconocido
    16 Jun 2008
    Gandia
    Alguien sabe de algún programa no muy difícil compatible con nuestro garmin para analizar, mejor nuestros entrenamientos, lo que busco es algún programa que me facilite analizar mis progresos y detectar zonas de mejora para incluir ejercicios en mis sucesivos entrenos...
  10. savedrage
    savedrage Miembro activo Probadores
    15 May 2014
    Argentina
    Y no lo tienes en la carpeta Courses tampoco?
  11. J0s3m4_7
    17 Jul 2011
    San Fernando
    Usa endomondo, o strava y prueba el strava labs y veloviewer
  12. scott_borja
    scott_borja Miembro activo
    10 Jul 2010
    Mentrida ( Toledo )
    Hola a todos, se Que esta pregunta se abra hecho mas de una vez, pero e estado mirando multitud de gps y e visto que garmin es el mejor para el mtb , lo que no se es por cual decantarme , si el dakota 20 , el edge 500 . Quiero que me sea practico para salir solo por rutas nuevas y descubrir caminos y bajarme algunas del wikiloc y pasarlas para segirlas . no lo quiero para mucho mas . no se si con el dakota 20 me llegara ? puesto que de precio creo que esta muy bien .
    Gracias de antemano
  13. El Quimérico Ciclista
    El Quimérico Ciclista MENTAL COACH
    27 May 2007
    Burgalencia
    Para los que tenéis problemas con el TIME MAP, la web oficial dice lo siguiente:
    1. http://www8.garmin.com/support/download_details.jsp?id=4747
    Updates & Downloads
    Time Zone Map software version 14.00
    as of March 4, 2014
    Use Garmin Express to install this file.
    (588 KB)
    View system requirements
    Notes:
      • Edge 500 users: If you are having problems updating the Time Zone Map on your Edge 500, please see thisFAQ for more information.
    2. https://support.garmin.com/support/...caseId={66180750-1b3d-11df-c0b1-000000000000}
    01/23/2014
    The "Fil_File.cpp" or "Exception :<?xml version" error can occur when attempting to update your Edge 500 via Garmin Express or WebUpdater. The error may also show as "Time Zone Map" transfer aborted. In short, both errors are rooted in the same failure.
    The error occurs when the gmaptz.img file within the Garmin directory of your Edge 500 is being overwritten by either update process. Since the gmaptz.img file, from the factory is read-only, the update process is unable to complete successfully, thus producing the error.
    In order to update your device successfully the gmaptz.img file will need to be deleted. Once this file is deleted, running the update process will complete without error.
    If you wish to delete the gmaptz.img file, please follow the directions below:
      1. Connect the Edge 500 to your computer
      2. Locate the gmaptz.img file which can be found in the Garmin Edge 500 > Garmin directory of your device
      3. Delete the gmaptz.img file
    Once deleted, you can load the latest software normally using Garmin Express or WebUpdater.
    Referenced articles:
    Garmin Express - http://software.garmin.com/en-US/express.html
    WebUpdater - http://www8.garmin.com/products/webupdater/howtoinstall.jsp
    En pocas palabras: 1) hay que borrar el archivo gmaptz.img y luego 2) actualizarlo con el Garmin Express.
  14. longines legend
    longines legend Miembro activo
    22 Sep 2013
    Tan lejos y tan cerca
    Hola,
    yo venía de la versión 3.0 y he actualizado a la versión 3.3, totalmente sin problemas. Decir que con Garmin express es mucho más rápido y sencillo, realmente es que no tienes que hacer nada.
    Pero tengo una duda, os comento por si me podéis echar una mano: en su día me da la impresión que creé 10 zonas de trabajo en garmin connect, pero ahora me gustaría eliminar zonas de trabajo y dejarlo en 5. El caso es que no consigo hacerlo, he mirado el manual y nada, que no puedo.
    Alguien que sepa como hacerlo.
  15. relayer
    28 Oct 2006
    Ya actualicé a la 3.3 y el nuevo firmware del chip del GPS y sin problemas. Hice todas las cosas que había que hacer, borrar las carpetas citadas, guardar los archivos de configuración, actualizar, el reset y recuperar los archivos de configuración. Tuve un susto. El Garmin Express empezó sin permiso y en una de las actualizaciones no terminó. Pero desconectando el Gps, pude seguir. Venía de la 2,8. Ahora la 3.2.
  16. genzime
    genzime Miembro activo
    13 Abr 2009
    Seguro que ya ha salido el tema
    ¿Sabeis cuantas horas es capaz de almacenar el garmin sin descargar las actividades?
  17. juanfcost
    juanfcost Miembro
    3 May 2013
    Muchas. Ahora mismo que yo recuerde he hecho unas 4 rutas entre 2 y 3h cada una y ahora mismo la batería está al 49%.
    Última edición: 18 Ago 2014
  18. juanfcost
    juanfcost Miembro
    3 May 2013
    Busca imágenes en Google o vídeos en youtube de como te muestra los caminos. Si es para seguir una ruta, aunque no es el mejor sirve, y si te desvías de la ruta te avisa, pero si es para explorar caminos nuevos e ir a la aventura no. Busca imágenes y vídeos y juzguelo usted mismo.
  19. kisco
    kisco Miembro activo
    24 Ene 2008
    Yo he actualizado y tengo problemas engancha los satélites al largo tiempo y encima me va poniendo 180km/h luego 0 y así y el otro día medio. Funciono y entonces no me había grabado el track que hago???,hecharmw un cable gracias ...por que estaba encantado con el y ahora me esta cabreando yaaa en las ultimas 4 salidas..
  20. longines legend
    22 Sep 2013
    A mi me dura entre 14-16 horas.
