Cuadro del Chino + portabotellin + manillar = 302€ en casita
Tema en 'Bicis y componentes' iniciado por Raúl Medín, 7 Ene 2009.
  1. Jubal
    Jubal Novato
    4 May 2009
    Trujillo, (Cáceres)
    Se que hay elementos mas ligeros y puede que de menor coste, pero he tenido un paron estival por unos dias de descanso y quiero retomar el trabajo de contruir mi puzzle personal, y para ello os pido consejo sobre estas cosillas que he encontrado en ebay, y en otras paginas. Tb que me deis consejos sobre que desbiador pillar tanto traseo como delantero, y que he de tener en cuanta en cuanto a medidas.
    Comienzo el baile de elementos:
    * Driveline X5 mtb crankset 7075 175mm 44/32/22T,975g
    Worldwide shipping by EMS express airmail service.
    EMS is more expensive but safer and faster and includes tracking number!!
    New Driveline X5 crankset Very light weight
    High quality Chainring:7075/T6 CNC alluminium
    44/32/22T
    Forged arms 175mm
    hollotec design Bottom Bracket Shells will fit either 68mm or 73mm
    cranks and bottom bracket+bolts weighs 975grams
    Kit includes both Crank arms /bolt/and Bottom Bracket
    (TOOLS not included, but installing tool is the same as shimano)
    * Hygia Elite hydraulic TWO-SIDED disc brakes,GREY
    [​IMG][​IMG][​IMG]
    Worldwide Shipping by EMS express mail service,includes tracking number!
    For bid is a brand newb Hygia Elite hydraulic TWO-SIDED disc brakes+rotors
    As you can see in the photo,
    the brake fluid resovior is INTEGRATED into the lever set,so this lever set can be used on left or right hand sides!!!
    This is OEM kit,so no box,limited sets
    Kit includes 2 caliper, 2 lever, brake pads, 2 rotors 160mm
    This disc brake set is suitable for 160mm discs.
    International Standard Mount adapter for 160mm disc included
    The color of this brake set is anondized like th 06XTR color! looks high-tech on your bikes
    Weight :
    Front without rotor:288g,hose length:680mm
    Rear without roto:314g, hose length:1280mm
    Factory description:
    A heavy-power full hydraulic disc brake set,equipped with artistic aluminum monobody caliper,superior in rigidity and sealing effect,capable of delivering large braking power thru twin active piston in open system design,the brake pads are self-adjustable;
    dexterous aluminum lever-set contains a hidden reservoir, flip-flop design allows left-and-right interchangeability, ergonomic 2-finger lever is reach-adjustable, proportional braking power to your grip force gives lag-free response;
    O aconsejais ir a por Shimano XTR? es que sumando lo que vale shimano en conjunto(desde los frenos hasta los cables, unos 950€), puedo pillar todos los elementos de diferentes marcas y me sobra algo de $$$$.
    Venga animarse a contestar que tengo ganas de comenzar a crear la burra y salir con ella.
  2. taotao
    taotao Miembro
    12 Ago 2007
    Lleida
    Buenas a todos, estoy pensando en comprar un cuadro de estos para probar, ya que tengo una doble y me gustaría probar una rígida un par de temporadas ya que me gusta ir siempre a tope y sobretodo cuando el desnivel es positivo, mi pregunta es que si me servirían las piezas de mi doble una canyon nerve xc 7 del 2007 o tendría que comprar y cambiar muchas de ellas. Gracias
  3. mav_1987
    mav_1987 Baneado
    23 Nov 2006
    no te puedo decir que estos componentes sean malo, pq nunca los he usado y nunca he escuchado opiniones sobre ellos. Por cuanto te salen estos componentes?? No seria mejor ir a lo seguro , es decir:shimano, sram,...
    A lo mejor por el mismo precio se encuentra algo similar y ya contrastado, en algunas de las tiendas onlines con precios cojonudos
  4. mav_1987
    mav_1987 Baneado
    23 Nov 2006
    en un principio te podría servir todas las piezas de tu Canyon XC7, a lo mejor tendrías que cambiar la dirección y el desviador delantero por uno de abrazadera alta (si tu canyon no la tiene ya), y por supuesto la horquilla por uno de 80 0 100 mm, ya que si no recuerdo mal la XC7 tenia 120mm de recorrido.
  5. taotao
    taotao Miembro
    12 Ago 2007
    Lleida
    La horquilla es una fox talas rlc de 100/120/140 se que no es una horquilla muy adecuada para una bici de este tipo pr de momento no podría montarla dejándola siempre en 100mm???
  6. el nata
    el nata maestro cansaliebres
    6 Abr 2007
    Vecino de Bahamontes
    En bielas casi mejor unas XT, acabo de destrozar unas nisu para sacarlas. Puedes poner el plato grande y pequeño ligero, si cambias el mediano puede dar problemas, y los tornillos. Los frenos parece que funcionan, y ademas las pastillas son iguales a las shimano
    Por lo menos para empezar a rodar vale, ya tendrás tiempo de buscar una mas adecuada
  7. mav_1987
    mav_1987 Baneado
    23 Nov 2006
    poder puedes, pero no es lo mas logico
  8. halmay
    halmay Miembro
    2 Abr 2009
    Me estoy tirando de los pelos¡¡ hace un mes que compre mi Orbea, si llego a saber de este post ahora mismo tendria una de carbono¡¡
    Quiero cambiar la potencia por una de estas de carbono, mi bicicleta es una Orbea Master... como puedo hacer la elección de la potencia?
  9. maxiiberico
    maxiiberico Miembro Reconocido
    28 Mar 2008
    en algún lugar del carril bici...
    Buenas, ya tenemos el pedido casi realizado, pero tengo unas dudas. Seria dos cuadros de 18", con tija, potencia, manillar, porta y direccion. Una cosa he visto dos tipos de cuadro, con direccion integrada y semi? q aconsejais? q diferencia hay? esos conponentes ( potencia, manillar, etc), merecen la pena? estan parando las cosas en aduana? es mejor hacer el pedido conjunto o por separado? Gracias y aver si me podeis ayudar. Esta semana formalizo el pedido. Gracias!
  10. mav_1987
    mav_1987 Baneado
    23 Nov 2006
    buenas noches!
    la diferencias de los cuadros no lo se , supongo q sera solo tema de diseño. el que me compre fue el de direccion integrada, y t epuedo decir que en persona gana muchisimo, es increible que cueste tan poco, viendo otros de MARCAS a un precio inalcanzable.
    En cuanto a los componentes, creo q la tila y la potencia no vale la pena pillarselo, pesan demasiados. Desde mi punto de vista, pillate junto con el cuadro la direccion y el manillar.
    Y por supuesto es mejor hacer el pedido por separado, para evitar llamar la atencion en las aduanas.
    Antonio
  11. maxiiberico
    28 Mar 2008
    es posible que no pillemos entonces ni tija ni potencia. y en cuento a hacer los dos pedidos por separado tabien es posible para no llamar mucho la atencion en aduanas. X cuento le habeis sacado con envio al chino cuadro, porta, direccion y manillar? es para saber cuanto puedo apretarle, contandole que tambien me lo pueden parar, etc.. llorandole vamos para que me rebaje el precio. Gracias por los mps y respuestas. un saludo!
  12. F. Catalan
    F. Catalan Ay!
    20 Jul 2009
    Salamanca
    A mi por cuadro, dirección, manillar, 3 punteras de cambio, 4 portas y el envío fueron 400$, es decir sobre 280€
  13. FueLex8
    FueLex8 Miembro
    4 Ene 2009
    Yo le pedi el puro cuadro, me salio en $300 USD.
    Ya casi la tengo armada, solo me falta montar las bielas y afinar los cambios... cuando este terminada pondre unas fotillos :eek:la
    PD: El cuadro es muy bonito, hasta ahorita a merecido la pena, solo falta probarlo.
  14. maxiiberico
    28 Mar 2008
    entonces semi o integrada? q cuadro elegir?
  15. mav_1987
    mav_1987 Baneado
    23 Nov 2006
    a mi me gusta mas integrada.
    mi cuadro me salido por 240€ (sin aduanas) y con una patilla
  16. tonivera
    tonivera Miembro
    26 Nov 2007
    Vamos, ahora con magura durin sl, a ver si consigo sub 9.
    Estoy en 9,221
  17. mav_1987
    mav_1987 Baneado
    23 Nov 2006
    *****!!!! preciosa tonivera!! ahora a ensuciarla!!!!! jajaa
  18. Ser Supremo
    Ser Supremo Miembro Reconocido
    14 Mar 2009
    Aqui picha
    Tonivera sabes cuanto te pesó el cuadro?
  19. Jubal
    Jubal Novato
    4 May 2009
    Trujillo, (Cáceres)
    Estimados compis de batallas, estoy dudando entre elegir:
    * sram x-0 + desviador trasero de carbono (SRAM X.0 Set Schalthebel+Schaltwerk) 270 €
    * Sram X.O XO Drehgriffe-Set Mod.2008 por 58,95€
    * Sram X.O Schaltwerk medium Carbon +Sram X.O Drehgriffe Mod.2009 189 €
    * Sram X.O Schaltwerk Redwin Red L + X.O Drehgriffe 2009 185 €
    He cogido esta marca pues por que veo que son campatibles con shimano y la duda esta ente coger manetas o pulsadores y las ofertas que hay.
    Que diferencia entre pulsador y manetas? cual mejor? cual mas ligera? cual mas comoda?
    un saludo
  20. Freddy M Tomas Vega
    Freddy M Tomas Vega Miembro
    31 Mar 2007
    miami,florida,usa
    disculpa cuanto mides y que talla es ese cuadro
    espectacular tu bike a disfrutarla
    salu2
