De Moviles y GPS´s
Tema en 'GPS' iniciado por dante, 2 May 2006.
  1. GoNzCiD
    GoNzCiD Miembro
    16 Nov 2010
    Es todo un ritual instalar el trekbuddy, casi se tienen que alinear los planetas, jeje. Ejecutar el archivo correspondiente teniendo los dos en el mismo directorio, crear y copiarte los diretorios que te dice que falta, permisos adecuados,... Luego los mapas con las capas que quieres de zoom. Despues de esto, que te funcione correctamente el backlight o tendras que instalar un servicio que no siempre lo soluciona y se te arranca por defecto al arrancar el telefono (con el correspondiente consumo de recursos)..
    Pese a todo ello en su web tienen foros de ayuda y documentacion en wiki....
    te dejo un fragmento:
    CODE, HTML o PHP Insertado:
    [edit] Install instructions
    Use PC Suite to install, or do it directly on the phone:
    1.	Copy trekbuddy.jar and trekbuddy.jad to the phone
    2.	In the phone, use "File Manager" to browse to trekbuddy.jad The file manager may be found e.g. in Menu -> Settings -> Data mgr -> File mgr (for N6220 classic)
    3.	Select it to start the installer
    4.	Optional but highly recommended: set permissions in application manager in order not to be asked dozens of time whether TrekBuddy is allowed to access the user data etc.
    1.	open App.Mgr (in German "Progr.-Man.") which you can find
    "	directly in ->Menu
    "	or directly in ->Tools
    "	or directly in ->System
    "	or in ->Menu/Tools->Applications
    "	or in ->Menu->Settings->Data mgr->App mgr->Installed apps
    2.	In the application manager, scroll to TrekBuddy, Options/Open, (Suite-)Settings and then set permission to "ask 1st time" or "always allowed" for the permission type you want, most important are Read user data and Edit user data - see general steps of installation (on top of page) for listing of relevant permissions.
    5.	That's it! Be sure to check out Symbian TrekBuddyService. It enables backlight control and support for TARed maps/atlases.
    Exception for install instruction (noticed with N6110 navigator): When getting an error message while installing: download the jar and the jad File to your phone via GPRS/UMTS/WiFi/USB-Cable(Datatransfer, not via the Nokia Application Installer) and manually start the installation process on your phone.
    Certificate error: On some S60 devices, Thawte certificate is not allowed to be used for application signing. To enable it, do (eg. N95, 6680):
    1.	go to Tools (or Menu)->Settings->General->Security->Certificate management-> MIDP2 Thawte->Options->Trust Settings
    2.	set Application installation option to Yes
    The MIDP2 Thawte Certificate may not be present in some 6210 Navigator Devices (see known Issues below)
    [edit] Configuration information
    Usually, C: is phone memory and E: is removable card. Hence, your TrekBuddy data dir may look like file:///E:/TrekBuddy (see Configuration).
  2. albertokaz
    albertokaz Miembro activo
    3 Sep 2009
    Que exagerados sois kopón!! cuesta un pokitin , sii pero teniendo encuenta que es totalmente gratis no está nada mal, tan solo hay que leer y preguntar, yo ya me creo rutas guiadas por voz y es una pasada. me es de gran ayuda en mis salidas...... sin él no me atreveria a meterme por donde me meto y nunca me ha dejado tirado jejeje
  3. GoNzCiD
    GoNzCiD Miembro
    16 Nov 2010
    Hombre, realmente no es que sea complicado extremadamente, pero podría tener un instalador normal y completo!
    Tras esto y cuando pruebas otros como twonav, al menos en mi caso lo vi claro.
  4. zaidin
    zaidin Miembro activo
    16 Mar 2011
    Granada
    Yo no tuve ningun problema para instalarlo. Recomiendo la versión 1.08, porque no suele dar problemas ni errores. Al ser una aplicación java, vale para cualquier sistema operativo de cualquier móvil. En caso de los nokia no hay que firmar la aplicación ni hackear el móvil.
    No hace falta utilizar un programa de sincronización pc-pda ni ningún complemento de software como los otros
    Para mí, (y he probado varios) ha sido el más fácil de instalar. Otra cosa es que sea en cuanto al funcionamiento el mejor y más sofisticado. Le cuesta cargar mapas, y no tiene zoom, entre otros defectillos, pero al menos, es un programa gratuito y nos puede hacer el apaño perfectamente.
  5. GoNzCiD
    GoNzCiD Miembro
    16 Nov 2010
    La version demo de twonav te sirve perfectamente para seguir rutas, y se instala desde el telefono y ejecutando un solo archivo. Por ejemplo.
  6. LCIRPM
    LCIRPM Esperando una respuesta
    18 Sep 2008
    LosCastillosIndependienteReivindicaPuertoMar
    He desistido del trekbuddy y he instalado el twonav. ¿Donde puedo encontrar un tutorial para torpes para instalar mapas y subir rutas?
  7. GoNzCiD
    GoNzCiD Miembro
    16 Nov 2010
    Cualquier mapa que encuentres calibrado te sirve, tan solo has de pasarlo a formato rmap con el compegps.
  8. ovalillos
    25 Ago 2008
    "De aquí de Madrid"
    Ya te habrán contestado, pero yo he llevado el garmin mobile y hasta que el touch me saltó de la bici y se destrozó, iba de lujo.
  9. Julen92
    Julen92 Miembro
    20 Abr 2010
    Vitoria - Gasteiz
    Muy buenas, tengo un nokia n97-mini ( symbian ) , apenas me se rutas y estoy cansado de ir siempre por las mismas.
    Sabeis algun gps para movil gratis y de facil manejo?
    Gracias de antemano
  10. Leioa
    Leioa Miembro activo
    23 Ene 2011
    LEIOA, BIZKAIA
    Hola a todos:
    Estoy intentando descargar desde la Tienda Ovi, el Sports Track, pero no me lo envía.
    ¿cual es la última versión en castellano para instalar en un Nokia X6?
    Solo necesito un programa que me de Velocidad, Distancia y Tiempo, pudiendo ver los tracks posteriormente en el ordenador, sin más pretensiones ¿alguna otra opción?
    Ya he revisado casi todo el post, y no encuentro ninguna referencia, excepto el Endomondo, parecido al Nokia Sports Track.
  11. Leioa
    23 Ene 2011
    LEIOA, BIZKAIA
    Bueno, pues ya he instalado el Nokia Sports Tracker, pero en inglés ¿tutorial para saber manejarlo?
  12. LCIRPM
    18 Sep 2008
    Si lo que quieres es ver los recorridos, yo uso el endomondo y va bastante bien. Para torpes como yo.
    El Nokia sport tracker lo he acabado desinstalando.
    A ver si soy capaz de instalar algo y hacerlo funcionar (trekbuddy, twonav ... ) para cargar y seguir rutas.
  13. Leioa
    23 Ene 2011
    LEIOA, BIZKAIA
    Hola. LCIRPM, es lo que busco, como buen patán de la informática.
    Sencillo, práctico, y a poder ser en castellano. Lo miro.
  14. GoNzCiD
    GoNzCiD Miembro
    16 Nov 2010
    no me puedo creer que te hagas con el endomondo y no con el sports-tracker! Para mi es mejor el sporttracker y no tiene nada. Simplemente entrar en ovi store e instalar!
    La unica ventaja que tiene el endomondo es que te lo sube en tiepo real. Yo, en muchas ocasiones llevo endomondo y sports-tracker a la vez. Sports-tracker siempre lo uso, endomondo para que desde casa sepan por donde voy...
    salu2
  15. Leioa
    23 Ene 2011
    LEIOA, BIZKAIA
    El sports tracker ya lo tengo, pero en ingles y sin instrucciones. No se como configurar la pantalla para que salga la altitud y no el ritmo cardiaco!!!
  16. GoNzCiD
    GoNzCiD Miembro
    16 Nov 2010
    Las pantallas creo que no se pueden configurar, desliza hacia arriba o abajo y recorres todas las opciones disponibles
  17. Leioa
    23 Ene 2011
    LEIOA, BIZKAIA
    Pero he visto alguna foto donde se sustituye, en la pantalla principal, el cuadrado del ritmo cardíaco, por la altitud, que me parece más interesante.
  18. GoNzCiD
    GoNzCiD Miembro
    16 Nov 2010
    igual era en versiones anteriores, se que se puede cambiar lo de la velocidad... pero el del ritmo cardiaco...
    O quizás dependa del perfil (bici, coche, personalizado,...)
    salu2
  19. Leioa
    23 Ene 2011
    LEIOA, BIZKAIA
  20. Leioa
    23 Ene 2011
    LEIOA, BIZKAIA
    ¡lo encontré! Cambiando la vista se puede ver todo, en números grandes, pero se desactiva los mapas.
