1. Tras 22 años de funcionamiento y muchas vivencias, lamentablemente, ha llegado el momento de decir adiós. Lo que empezó siendo un pequeño foro de "backup" de la web que muchos solíamos visitar, Solomountainbike, se convirtió en una web de referencia del ciclismo en general donde se compartían rutas, vivencias, fotos, kdds, etc.
Garmin Edge 820
  1. Strms
    Strms Miembro
    16 May 2017
    Palma
    En el primer post aparece como hacerlo. Es mas fácil de lo que parece si sigues las instrucciones.
  2. Strms
    Strms Miembro
    16 May 2017
    Palma
    Que trae la v.11?
  3. Strms
    Strms Miembro
    16 May 2017
    Palma
    Que trae la v.11?
  4. wilson60
    wilson60 Miembro
    16 Dic 2016
    Valladolid
    Changes made from version 10.00 to 11.00:
    New Feature: Galileo satellites. There is now support to use the Galileo network of satellites to assist in getting GPS fixes. With the correct GPS firmware, this option can be enabled by selecting GPS+Galileo in the GPS setting. Sync the device with Garmin Express to make sure that the new line of GPS firmware is provided to the device. Without this, the option will not be available.
    Added cycling dynamics support for 3rd party power sensors.
    Updated smart notification categories. In the phone settings, social and other smart notification categories can be enabled. This will make the Edge show notifications from other applications depending on how they are categorized by Garmin Connect Mobile. Apps like WhatsApp, GroupMe, and Twitter may show up under social and things like e-mail, calendar, and news may show up under other. These categories are off by default and must be enabled to be seen.
    Fixed an issue causing cadence and power data dropouts.
    Updated indoor trainer UI to properly disable GPS when activated and no longer try to calculate routes while active.
    Fixed issue where FTP data would not be uploaded to Garmin Connect correctly.
    Fixed crash when doing a calculation with automotive routing selected.
    Added ability to select CIQ data fields on the map page.
    Added prompt to indicate when a course has more course points than are supported by the device.
    Fixed issue with transmitting front and rear gear information to the Varia Vision.
    Added ability to stop the course from the course review page of the active course to make it easier to reactivate a course.
    Updated the incident detection interface to better indicate when the user is trying to dismiss the page by holding the specified area.
    Fixed crash when using Varia Vision with workouts.
    Fixed issue where the GPS data field did not match the GPS indicated by the status bar.
    Fixed issue when coming out of mass storage mode that could cause a crash.
    Added the current software version to the power on page.
    Fixed issues with device transfers.
    Completing a segment will now turn on the backlight.
    Added a minimum scale to the altimeter page so that small elevation ranges are reflected properly.
    Fixed elevation zooming issue with large courses/activities/segments (>100mi or km).
    Updated radar tone to be easier to hear.
    Minor graphics improvements.
    Minor bug fixes and stability improvements.
    Minor CIQ improvements.
    Enviado desde mi VTR-L09 mediante Tapatalk
  5. NOLOMAN
    NOLOMAN Miembro activo
    13 Nov 2009
    Pontevedra
    como resumen, lo mas importante es que ahora se pueden recibir notificaciones de redes sociales (whastapp..etc), y el nuevo modo GPS-Galileo, ademas de toda las correcciones de errores (muchos a mi parecer) que menciona en su apunte Wilson60.
    Eso si, a mi por lo pronto me ha generado un error que no tenia, igual es cuestión de que se actualice también las IQ de Strava y Wikiloc al nuevo software, esperaré unos días a ver que pasa.
  6. NOLOMAN
    13 Nov 2009
    Pontevedra
    también avisa y se pueden leer los mail de tu correo electrónico,
  7. axterixxx
    axterixxx Miembro activo
    17 Ene 2012
    hola ami también me actualizado al 11.0. también me da error IQ de wikiloc y strava.
    Otra cosa como tengo dos bicis una montaña y una carretera. Como puedo hacer para identificar una o otra , que me separe el km de montaña y la de carretera etc ... en la de montaña no llevo sensores
    Última edición: 10 Ene 2019
  8. axterixxx
    17 Ene 2012
    alguien a probado ya si se recibe wasap?
    con el gps galileo sera mas preciso?
  9. NOLOMAN
    13 Nov 2009
    Pontevedra
    yo lo he probado, y puedo leer los whatsapp y mail, hay que habilitar la opción de notificaciones de redes sociales y otros, que aparece desactivada por defecto . En cuanto al la conexion GPS-Galileo todavía no he tenido oportunidad de probarla en ruta, este finde lo testare.
  10. NOLOMAN
    13 Nov 2009
    Pontevedra
    configuracion/telefono/Notific.inteligentes/.... y aquí se activa redes sociales y otros.
  11. Javi2246
    Javi2246 Miembro Reconocido
    23 May 2012
    No me salta la actualizacion ni por el pc, ni movil....alguno podria subir el firm xfvr?
  12. Tolotarmac
    Tolotarmac Miembro Reconocido
    15 Dic 2016
    Palma de Mallorca
    Lo del WhatsApp está bien y es un coñazo a la vez, para urgencias perfecto, pero hay que silenciar los grupos, no para de sonar, si sólo ponemos los que nos intersan, por mí parte mí mujer y poco más, es perfecto, gracias al forero que me informó cómo hacer para que sólo avisara según que mensajes.
  13. Joan89
    Joan89 Pedaleador
    15 Feb 2006
    lands
    Hola, soy nuevo en gps's y he adquirido un 820.
    Estoy un poco preocupado por que lo primero que hay que hacer ya no lo se hacer.
    Al conectar el gps con el móvil por bluetooth, sigo las indicaciones y garmin conect me da "error de ajuste", los dos dispositivos con el bluetooth conectado se localizan y se enparejan, pero al querer vincular el dispositivo a Garmin Conect me sale este error.
    He desvinculado los dos bluetooth, he desinstalado y reinstalado la app, pero me continua saliendo este error. No se que estaré haciendo mal, necesito ayuda.
    Mi versión de Garmin connect es la 4.13.7
  14. danigs
    danigs Miembro Reconocido
    10 Sep 2004
    Tarragona
    A mi si me funciona la aplicación IQ de wikiloc tras actualizar a la versión 11.
  15. danigs
    10 Sep 2004
    Tarragona
    Prueba con Garmin WebUpdater.
  16. Javi2246
    23 May 2012
    Gracias, acabo de probar otra vez con el express y ya me ha saltado.
    A ver si han corregido los bugs de la beta
  17. axterixxx
    17 Ene 2012
    yo lo tengo activado los wasa y no me aparece en el garmin, ¿a alguien también le pasa?
  18. axterixxx
    17 Ene 2012
    Otra cosa como tengo dos bicis una montaña y una carretera. Como puedo hacer para que me registre la actividad cada una en la la suya. crear perfiles para cada bici. la de montaña no tiene sensores.
    Última edición: 11 Ene 2019
  19. Strms
    Strms Miembro
    16 May 2017
    Palma
  20. NOLOMAN
    13 Nov 2009
    Pontevedra
    tienes que ademas activar la aplicaciones que quieres notifiquen, para eso debe ir a la aplicación Garmin connect del teléfono que tengas vinculado, y entrar en configuración/notificaciones inteligentes , y ya ahí activar o desactivar las que te interesen envíen notificaciones al Garmin
