Discussion in 'GPS' started by santacruzblur, Jun 4, 2008.
  1. santacruzblur
    Following the track
    A mi personalmente no,comentaros que he realizado la actualizacion, y despues le he realizado un hard reset, a ver que tal ira.........a ver que han arreglado y que se han cargado, por cierto esperare 2 dias para mandar la lista definitiva a garmin, si alguien quiere aportar algo mas que me avise .
  2. krono
    krono Miembro
    A mi me pasa lo mismo con el Edge 705. Y no tengo ni idea de porqué es. Y la verdad es que es una guarrada pq no puedes ni descifrar los nombres. Carretera de L.....que Leches será esto???
    A alguien le pasaba y lo ha solucionado????
    A ver que arreglos trae la 2.30. Voy a ver si está la lista de cosas que arregla....
  3. krono
    krono Miembro
    Aquí esta la lista de cambios de la 2.20 a la 2.30, pero vamos, que la he tenido que buscar a lo bestia en el google pq no la he encontrado en la web de garmin.
    Changes made from version 2.20 to 2.30:
    * Removed time limitation from history recording.
    * Deleting history through the menu on the device will now also delete the history file from mass storage.
    * Fixed issue where averages and calories could accumulate when auto-paused.
    * Fixed issue where workout dates could be incorrect on the watch when loaded from the PC.
    * Fixed issue where settings were sometimes not saved when GPS was turned off.
    * When creating a course, device will no longer show history that does not have track point data.
    * Correct issue with repeated auto-pause/resume when starting.
    * Fixed issue where routes created in MapSource could have invalid points after being loaded to the Edge.
    * Fixed some problems with calculating total ascent.
    * Fixed issue with grade being dashed and elevation not changing.
    * Added an Entertainment category in POI List.
    * Speeded up searching in Find Cities.
    * Fixed issue where wheel size was not auto-calibrating.
    * Fixed issue where unit does not return to previous screen after route recalculation.
    * Added progress bar for software updates.
    * Added ability to hit LEFT/RIGHT to toggle between Bike Computer pages and Course Points page.
    * Fixed problem with Time to Point display on course data page.
    * Allow UP and DOWN to cycle the bottom pane of data on the Course Timer screen.
    * Fixed some issues that would allow creating an invalid course that would end as soon as you pressed start.
    * Fixed issue where certain languages (Svenska, Magyar, Slovensky) would not work with course compass page.
    * Fixed issue where when more than one mapset is installed the unit only searches for addresses on the closest mapset.
    * Fixed issue where keyboard would not immediately update when switching modes.
    * Improved route recalculation.
    * Fixed issue where ?Arriving At...' message does not always show destination.
    * Disabled panning on the map displayed on the course timer page.
    * Fixed issue where the Course Elevation Profile shows a straight line on long activities.
    * Added average power to the lap data in XML.
    * Updated many German translations.
    * Fixed issue where auto-pause/manual lap causes 0 distance lap.
    * Changed zoom levels at which towns and villages appear based on size to help declutter the map.
    * Increased the number of calories that can be shown on History Totals page.
    * Made some changes to reduce 0 speed reporting when using GSC10.
    Al parecer solucionan lo de que se borre de verdad el historial, lo de que se grabe la configuracion (perfiles, etc..) de verdad, y algún otro problema que he visto en otros foros sobre al autocalibrado de rueda. Y luego otros muchos fallos que ni conocía.....
    Pero no pone nada de que se solucionen los apagones. Solo hace referencia a que han arreglado el que cuando creabas una ruta con el Mapsource, al pasarla al EDGE le salían puntos incorrectos como por arte de magia. ¿Será eso parte de culpa de los apagones?
    Pues nada, a actualizar y a hacer un hard-reset, y a rezar!!!!
  4. menamoli
    menamoli Miembro activo
    Getafe (Madrid)
    Habeis hecho un hard resaet despues de actualizar? yo no es mas ayer despues de actualizarlo me huy a hacer una ruta y todo bien. Por cierto el hard reset borra algo o no?
    Jesus
  5. ElCidCampero
    ElCidCampero Miembro
    Lugo
    Otra preguntilla. Ayer me di una vuelta de 50 kilómetros y llevaba tanto el Garmin 605 como un pulsómetro Polar CS200. Tanto uno como el otro están correctamente configurados en cuestión de pesos y demás, pero es que el Garmin 605 me dijo que había consumido 1700 calorías mientras que el polar me dice 1050. Y la distancia, velocidad instantanea y velocidad media coinciden muy muy bien. ¿Cual de las dos medidas es mas realista? Porque uno tiene en cuenta el perfil de la etapa, pero el otro las pulsaciones, etc ...
  6. fisico
    fisico Miembro
    Valladolid
    Podéis mirar si os ocurre esto.
    Menu ---> Entrenamiento ---> Sesiones de ejercicio ---> Avanzadas ---> Crear
    Dentro de los pasos si quiero eliminar alguno de ellos se apaga el aparatito al dar aceptar.
    Al igual que das a Crear y dentro de pasos quieres ir para atrás pulsando a mode el aparato también se apaga.
    CREO QUE ES UN ERROR QUE NOS PUEDE PASAR A TODOS.
  7. elorenzo1
    elorenzo1 Eme
  8. santacruzblur
    Following the track
    Con El Wepupdate La Descargas Directamente
  9. elorenzo1
    elorenzo1 Eme
    Muchas gracias ya lo he actualizado.
  10. Whitehair
    Whitehair Miembro Reconocido
    Rivas
    A mi tambien me pasaba eso.
    Voy por el segundo 605 que envio, ya os contare con el tercero como me va, espero tener la suerte de santacruzblur.
  11. menamoli
    Getafe (Madrid)
    SantacruzBlur queria preguntarte una cosa yo tengo un protector de pantalla de los que has recomendado pero como no soy muy bueno colocandolo pues me ha salido bien despues de una pocas veces intentandolo pero lo que me ha pasado es que de intentarlo tantas veces la cara por la que se pega se ha ensuciado ¿eso hay manera de limpiarlo?.
    un saludo
    jesus
  12. santacruzblur
    Following the track
    Pues viendo lo visto , te diria que te fiases mejor del polar, yo tengo el cs 600, y si hay una cosa de los polar ,es que son muy fiables, y en cuanto a seguridad de precision de la F.C me quedo con polar.
  13. santacruzblur
    Following the track
    Hola menamoli, te cuento , ya llevo puestos unos cuantos invisible shield, y algo que hay que tener en cuenta antes de manipularlos, es lavar las manos antes de manipularlos, y pulverizar sobre las llemas de los dedos, parte de liquido que te viene con el Invisible shield, para no dejar marcada la cara adhesiva con marcas de huellas dactilares.
    Otra cosa, yo los tengo despegados muchas veces, porque siempre te puede entrar una motilla de polvo o algo, y lo que hago, es despegarlo y lavarlo debajo de un grifo con abundante agua y gel de ducha, y comprobado, le quita toda la suciedad que tenga, eso si una vez lavado ni se te ocurra pasarle un paño ni nada, (se te pegaria la pelusilla), sino que directamente lo pones encima de la pantalla del Garmin, y listo_Otra cosa impportante, es dejarlo secar al menos 24 horas, para que no se mueva, y desaparezcan las burbujas.
    Por ultimo si se os acaba la solucion que viene en el pulverizador, rellenadlo con agua con un poco de gel de ducha, y vereis como es mejor que el liquido original.
    un saludo.
  14. santacruzblur
    Following the track
    Por cierto se me olvidaba, lo he actualizado como ya he comentado, le he realizado el hard restet (por si acaso), y de momento CERO problems..........toco madera.Por cierto 1 dia para mandar la lista de fallos a Garmin....ya queda menos.
  15. 1ques2
    Gelida (Barcelona)
    Hola Fisico y Whitehair, a mi también me pasa lo de las sesiones avanzadas. En español hay errores de programa. Yo lo pongo en inglés y creo la sesión sin problemas ni signos raros.
    Probad vosotros.
    Javier
  16. Whitehair
    Rivas
    Gracias por el aviso.
  17. STS
    STS Re-enganchado
    respecto a la lista de bugs, hay uno que no se si esta solucionado con la última actualización, ya que no puedo salir con la bici,
    es dentro de las cosas que puedes elegir para que aparezca en la pantalla de datos, el "ETA en dest" (tiempo estimado en destino), que no muestra nunca nada
  18. fisico
    fisico Miembro
    Valladolid
    Muchas gracias.
    Creo que SantaCruz debería tomar nota ya que es un error garrafal.
  19. fisico
    fisico Miembro
    Valladolid
    Por cierto otra cosilla.
    Después de instalar la 2.30 buenas noticias, es la primera vez que el garmin no se me apaga, claro esta tengo que hacer más salidas con el, pero ayer hice unos 45km y todo perfecto.
  20. menamoli
    Getafe (Madrid)
    Gracias Santacruz por tu informacion antes de que mandes los fallos a garmin no se si habias visto esto que te habia puesto en un mensaje anterior para que lo inclulleras en la lista.
    Bueno una cosa que tambien espero que la inclullas se trata sobre el historial el sabado despues de hacer una ruta cuando acabe le di al Stop y al reset 3-2-1 pues bien todo ok pero despues de hacer eso un amiguete me comento que queria ver el perfil y mas datos total que me meti en el historial pensando que podria ver esos datos y mi sorpresa fue que no.
    Pues bien resuniendo que podrian incluir que si seleccionas una actividad del historial que pudiesemos ver el perfil, mapa y los datos de tiempos, velocidades etc.
    Un Saludo
    Jesus
