VENDIDA Pues eso que se vende esta bici, está como nueva, impecable, con todo el equipamiento de serie más pedales automáticos, bolsa de herramientas y cuenta kilometros inalambrico. De serie trae lo siguiente: HORQUILLA Marzocchi MZ Race LO, 100mm, coil/MCU without boots, 30mm Cro-Mo stanchions, damped w/ lockout & preload adjust DIRECCION 1 1/8" threadless POTENCIA Specialized 3D forged alloy, four bolt, 31.8mm, 7 degree rise MANILLAR Alloy 31.8mm, 38mm rise, 640mm wide, 8 degree back, 6 degree up sweep, 3.2mm thick CINTA / PUÑOS Specialized Enduro, dual density Kraton FRENO DELANTERO Hayes Sole, hydraulic disc, 6" v-cut rotors FRENO TRASERO Hayes Sole, hydraulic disc, 6" v-cut rotors PALANCAS DE FRENO Hayes Sole w/ BFL lever DESVIADOR Shimano Deore M-530 CAMBIO SRAM SX-5 MANDOS DE CAMBIO SRAM SX-5 9-speed triggers CASETE/RUEDA LIBRE Shimano MFHG-50, 9-speed, 11-34t CADENA Shimano HG-73, 1/2" x 3/32" w/ missing link PEDALIER Shimano FCM-442-8, Octalink Spline, 9-speed, replaceable rings w/ alloy outer PLATOS 44A/32S/22S CAJA PEDALIER Shimano ES-25, Octalink Spline, cartridge bearing, 68 x 118mm for 50mm chainline LLANTAS Specialized/Alex HRD 26, double wall disc w/ eyelets BUJE DELANTERO Specialized Hi Lo disc, 36h, CNC flange and disc mount, QR BUJE TRASERO Shimano M-475 Disc, cassette, 36h RADIOS 2.0mm (14g) stainless NEUMATICO DELANTERO Specialized Resolution, 26x2.1", 60TPI, wire bead NEUMATICO TRASERO Specialized Resolution, 26x2.1", 60TPI, wire bead CAMARAS Specialized schraeder valve SILLIN Specialized Body Geometry, ATB TIJA DE SILLIN Alloy micro adjust, 30.9mm ABRAZADERA SILLIN Alloy collar w/ QR PRECIO DE CATALOGO 789€ PRECIO DE VENTA 575€ FOTOS EN ESTE ENLACE http://www.flickr.com/photos/21964351@N06/ CONTACTO MEDIANTE MENSAJE PRIVADO Arriba
Haber ahora que estamos en un nuevo año, que na diese anima ??? Si el problema es el precio, ir dando ofertas haber si llegamos a un acuerdo :walkman
