Todo lo nuevo en 650B, 27,5"
Discussion in 'Rally/X-Country/Maratón' started by DHAndalucia, Jan 30, 2013.
  1. DHAndalucia
    DHAndalucia Miembro Reconocido
    Malaga
  2. DHAndalucia
    Malaga
    Norco Sight 650B
    [​IMG][​IMG]
  3. DHAndalucia
    Malaga
    2014 FOES FXC 275 650B
    [​IMG] [​IMG]
  4. DHAndalucia
    Malaga
    2014 Yeti SB75 650B
  5. DHAndalucia
    Malaga
  6. DHAndalucia
    Malaga
    2014 Pivot LES 650B
  7. DHAndalucia
    Malaga
    Scott Spark 650B
    [​IMG] [​IMG] [​IMG]
  8. DHAndalucia
    Malaga
    Pivot Mach 6 650B
  9. DHAndalucia
    Malaga
    Norco Range 650B
    [​IMG] [​IMG] [​IMG] [​IMG]
  10. DHAndalucia
    Malaga
    Yeti SB75 650B
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
  11. DHAndalucia
    Malaga
    Intense Carbine 650B
  12. DHAndalucia
    Malaga
    Turner Burner 650B
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
  13. DHAndalucia
    Malaga
  14. ray
    ray ACCMIC MEMBER
    Quien la fabrica..???
  15. DHAndalucia
    Malaga
    Formula
  16. DHAndalucia
    Malaga
    Ghost Cagua 6590 650B
    http://www.chainreactioncycles.com/es/es/ghost-cagua-6590-suspension-bike-2014/rp-prod111443
    Precio 5,441 €
    Specifications:
    • Frame: Cagua 650B Actinum DB
    • Stem: GHOST Light AS 29 31.8 mm
    • Forks: FOX Forx 34 Talas FIT CTD Kashima 160/120 mm
    • Handlebars: GHOST Low Rizer super light 740 mm 31.8 mm
    • Seatpost: Rock Shox Reverb 31.6 mm Travel 125 mm
    • Saddle: Selle Italia SLR
    • Rear Derailleur: SRAM X.0 Type 2 10-Speed
    • Front Derailleur: SRAM X.0
    • Shifter: SRAM X.0 Trigger
    • Crankset: SRAM X.0 38-24 / 11-36
    • Brakes: Shimano XT Disc 203 / 180 mm SMRT67
    • Tyres: Schwalbe Nobby Nic 2.35
    • Rims: Alex MD 23
    • Rear Hub: Shimano XTR 12 mm
    • Front Hub: Shimano XTR 15 mm
    • Shock: FOX Float CTD BV SV XV Kashima Trail Adjust 150 mm
    • Front Travel: 160 / 120mm
    • Rear Travel: 155mm
    • Weight: 13.6 kg
  17. DHAndalucia
    Malaga
    Pacenti Prototype 650B
  18. DHAndalucia
    Malaga
    2014 Lapierre Spicy 527 650B
    http://reviews.mtbr.com/compare-o-first-look-lapierre-spicy-527
    Precio 5,300 $
    2014 Lapierre Spicy 527 Key Specs
    • Weight: 30.97 (size medium, without pedals)
    • Wheel Size: 27.5 inches
    • Frame Material: Aluminum
    • Travel/Suspension: Rear: 150mm/E:i RockShox Monarch RT3; Front: 160mm/Fox 34 Float CTD Performance FIT
    • Drivetrain: SRAM X7, Shimano XT; 2×10 11-36t; Race Face Turbine crankset 36/22t
    • Brakes: Avid Elixer 7, 200mm front, 180mm rear
    • Seatpost: RockShox Reverb Stealth, 125mm drop
    • Wheelset/Tires: Easton 27.5-inch Vice XLT tubeless wheels, Schwalbe Hans Dampf 2.35-inch tires
    • Bars/Stem: Race Face Atlas Stealth, 740mm bars; Race Face Turbine, 60mm
    • Bottom Bracket Type: Shimano Press Fit
    • Head Tube Angle: 66.5 degrees
    • Seat Tube Angle: 73.5 degrees
    • Chainstay Length: 16.75 inches
    • Bottom Bracket Height: 12.25 inches
    • Bike MRSP: $5300
    • Frame MSRP: N/A
  19. DHAndalucia
    Malaga
    [​IMG] [​IMG]
  20. herot
    herot Miembro Reconocido
    Que es ese artilujio que lleva en la barra, tambien veo que el amortiguador va monitorizado por el cuanta km, imagino que eso sera para lo mismo no ???
